Beam Design - Foot Bridge
Size: 4 x 8
Design Span (L): 15.33 ft.
Clear Span: 14.67 ft.
Total Span: 16.00 ft.
Bearing (lb): 8 in.
Live Load: 500 lbs
Dead Load: 75 lbs
Selfweight: 277.2 lbs
Dist. Selfweight: 18.08 plf
Total Weight: 289.3 lbs
Notes: Point Load
Beam Design 001
4/19/2022 1
Beam Design 001
4/19/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [25.38 x (184.00 + 8)] x (12 in./ft.)3 = 8.46 ft3
Volumespan = N[A x L] = 3 x [25.38 x 184.00] x (12 in./ft.)3 = 8.11 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 8.46 = 289.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 8.11 = 277.2 lbs
Distributed Self Weight (ws) = = 18.08 plf
500 lbs
75 lbs
ws = 18.08 plf
15.33 ft.
14.67 ft.
432.15 lbs
432.15 lbs
Beam Design 001
4/19/2022 3
fb = = 356.9 psi
 fb = 356.9 psi < Fbx' = 1345.5 psi  (CSI = 0.27)   ➜  OK
Beam Design 001
4/19/2022 4
fv* = = 8.18 psi
 fv* = 8.18 psi < Fvx' = 207.00 psi  (CSI = 0.04)   ➜  OK
fv = = 8.40 psi
 fv = 8.40 psi < Fvx' = 207.00 psi  (CSI = 0.04)   ➜  OK
Beam Design 001
4/19/2022 5
ΔLL =   =   = 0.12 in.
(L/d)LL = 184.00 / 0.12 = 1513
 ΔLL = 0.12 in = L/1513 < L/360   ➜  OK
ΔTL =   =   = 0.18 in.
(L/d)TL = 184.00 / 0.18 = 1011
 ΔTL = 0.18 in = L/1011 < L/240   ➜  OK
fc⊥ = = 5.1 psi
 fc⊥ = 5.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.01)   ➜  OK
Beam Design 001
4/19/2022 6
