Beam Design - Foot Bridge
Size: 4 x 8
Design Span (L): 15.33 ft.
Clear Span: 14.67 ft.
Total Span: 16.00 ft.
Bearing (lb): 8 in.
Selfweight: 277.2 lbs
Dist. Selfweight: 18.08 plf
Total Weight: 289.3 lbs
Beam Design 001
4/19/2022 1
Beam Design 001
4/19/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [25.38 x (184.00 + 8)] x (12 in./ft.)3 = 8.46 ft3
Volumespan = N[A x L] = 3 x [25.38 x 184.00] x (12 in./ft.)3 = 8.11 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 8.46 = 289.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 8.11 = 277.2 lbs
Distributed Self Weight (ws) = = 18.08 plf
ws = 18.08 plf
15.33 ft.
14.67 ft.
1544.62 lbs
1544.62 lbs
Beam Design 001
4/19/2022 3
fb = = 740.2 psi
 fb = 740.2 psi < Fbx' = 1345.5 psi  (CSI = 0.55)   ➜  OK
Beam Design 001
4/19/2022 4
fv* = = 26.87 psi
 fv* = 26.87 psi < Fvx' = 207.00 psi  (CSI = 0.13)   ➜  OK
fv = = 29.17 psi
 fv = 29.17 psi < Fvx' = 207.00 psi  (CSI = 0.14)   ➜  OK
Beam Design 001
4/19/2022 5
ΔLL = = 0.23 in.
(L/d)LL = 184.00 / 0.23 = 789
 ΔLL = 0.23 in = L/789 < L/360   ➜  OK
ΔTL = = 0.45 in.
(L/d)TL = 184.00 / 0.45 = 409
 ΔTL = 0.45 in = L/409 < L/240   ➜  OK
fc⊥ = = 18.4 psi
 fc⊥ = 18.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.03)   ➜  OK
Beam Design 001
4/19/2022 6
