Grade: SPF SS
Design Span (L): 19.67 ft.
Clear Span: 19.33 ft.
Total Span: 20.00 ft.
Bearing (lb): 4 in.
Live Load: 40 plf
Dead Load: 50 plf
Selfweight: 165.4 lbs
Dist. Selfweight: 8.41 plf
Total Weight: 168.2 lbs
Incised Lumber: Yes
Beam Design 495
4/18/2022 1
Beam Design 495
4/18/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (236.00 + 4)] x (12 in./ft.)3 = 5.78 ft3
Volumespan = N[A x L] = 3 x [13.88 x 236.00] x (12 in./ft.)3 = 5.68 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 5.78 = 168.2 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 5.68 = 165.4 lbs
Distributed Self Weight (ws) = = 8.41 plf
40 plf
50 plf
ws = 8.41 plf
19.67 ft.
19.33 ft.
984.13 lbs
984.13 lbs
Beam Design 495
4/18/2022 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.1)(0.8)(1) = 1265.0 psi
fb = = 889.7 psi
 fb = 889.7 psi < Fbx' = 1265.0 psi  (CSI = 0.70)   ➜  OK
Beam Design 495
4/18/2022 4
Fvx' = (135)(1.15)(1)(1)(0.8) = 124.20 psi
fv* = = 32.14 psi
 fv* = 32.14 psi < Fvx' = 124.20 psi  (CSI = 0.26)   ➜  OK
fv = = 34.87 psi
 fv = 34.87 psi < Fvx' = 124.20 psi  (CSI = 0.28)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1500000(1)(1)(0.95) = 1425000 psi
Beam Design 495
4/18/2022 5
ΔLL = = 0.32 in.
(L/d)LL = 236.00 / 0.32 = 741
 ΔLL = 0.32 in = L/741 < L/360   ➜  OK
ΔTL = = 0.78 in.
(L/d)TL = 236.00 / 0.78 = 301
 ΔTL = 0.78 in = L/301 < L/240   ➜  OK
fc⊥ = = 54.7 psi
 fc⊥ = 54.7 psi < Fc⊥x' = 425.00 psi  (CSI = 0.13)   ➜  OK
Beam Design 495
4/18/2022 6
