Beam Design - Foot Bridge
Size: 4 x 8
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Quantity (N): 4
Selfweight: 379.7 lbs
Dist. Selfweight: 24.11 plf
Total Weight: 385.7 lbs
Beam Design 001
4/18/2022 1
Beam Design 001
4/18/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [25.38 x (189.00 + 3)] x (12 in./ft.)3 = 11.28 ft3
Volumespan = N[A x L] = 4 x [25.38 x 189.00] x (12 in./ft.)3 = 11.10 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 11.28 = 385.7 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 11.10 = 379.7 lbs
Distributed Self Weight (ws) = = 24.11 plf
ws = 24.11 plf
15.75 ft.
15.50 ft.
1592.87 lbs
1592.87 lbs
Beam Design 001
4/18/2022 3
fb = = 604.1 psi
 fb = 604.1 psi < Fbx' = 1170.0 psi  (CSI = 0.52)   ➜  OK
Beam Design 001
4/18/2022 4
fv* = = 21.39 psi
 fv* = 21.39 psi < Fvx' = 180.00 psi  (CSI = 0.12)   ➜  OK
fv = = 23.17 psi
 fv = 23.17 psi < Fvx' = 180.00 psi  (CSI = 0.13)   ➜  OK
Beam Design 001
4/18/2022 5
ΔLL = = 0.19 in.
(L/d)LL = 189.00 / 0.19 = 971
 ΔLL = 0.19 in = L/971 < L/360   ➜  OK
ΔTL = = 0.39 in.
(L/d)TL = 189.00 / 0.39 = 488
 ΔTL = 0.39 in = L/488 < L/240   ➜  OK
fc⊥ = = 37.9 psi
 fc⊥ = 37.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.06)   ➜  OK
Beam Design 001
4/18/2022 6
