Beam Design - Bauer Residence
Size: 3.125 x 18
Design Span (L): 25.29 ft.
Clear Span: 24.83 ft.
Total Span: 25.75 ft.
Bearing (lb): 5.5 in.
Selfweight: 333.6 lbs
Dist. Selfweight: 13.19 plf
Total Weight: 339.6 lbs
CV Volume Factor 0.990b - - - - -
Beam Design Matthew Bauer 4634 E Wilshire Dr. 21-034
4/16/2022 1
b = 3.125 in.
d = 18.000 in.
A = 3.125 x 18.000 = 56.25 in.2
Sx = (3.125)(18.000)2/6 = 168.75 in.3
Sy = (3.125)2(18.000)/6 = 29.30 in.3
Ix = (3.125)(18.000)3/12 = 1518.75 in.4
Iy = (3.125)3(18.000)/12 = 45.78 in.4
4/16/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [56.25 x (303.50 + 5.5)] x (12 in./ft.)3 = 10.06 ft3
Volumespan = N[A x L] = 1 x [56.25 x 303.50] x (12 in./ft.)3 = 9.88 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 10.06 = 339.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 9.88 = 333.6 lbs
Distributed Self Weight (ws) = = 13.19 plf
  ws = 13.19 plf
25.29 ft.
24.83 ft.
25.75 ft.
2422.95 lbs
2422.95 lbs
4/16/2022 3
CV = = 0.990
CV = 0.990 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.990) = 2733.4 psi
fb = = 1070.1 psi
 fb = 1070.1 psi < Fbx' = 2733.4 psi  (CSI = 0.39)   ➜  OK
4/16/2022 4
fv* = = 55.93 psi
 fv* = 55.93 psi < Fvx' = 304.75 psi  (CSI = 0.18)   ➜  OK
fv = = 63.46 psi
 fv = 63.46 psi < Fvx' = 304.75 psi  (CSI = 0.21)   ➜  OK
4/16/2022 5
ΔLL = = 0.34 in.
(L/d)LL = 303.50 / 0.34 = 901
 ΔLL = 0.34 in = L/901 < L/360   ➜  OK
ΔTL = = 0.63 in.
(L/d)TL = 303.50 / 0.63 = 479
 ΔTL = 0.63 in = L/479 < L/240   ➜  OK
Ab = b x lb = 3.125 x 5.5 = 17.19 in2
fc⊥ = = 141.0 psi
 fc⊥ = 141.0 psi < Fc⊥x' = 650.00 psi  (CSI = 0.22)   ➜  OK
4/16/2022 6
