Beam Design - Lisa Green Condo
Grade: DF No.1
Design Span (L): 6.25 ft.
Clear Span: 6.00 ft.
Total Span: 6.50 ft.
Live Load: 315 plf
Dead Load: 210 plf
Selfweight: 25.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 26.1 lbs
Notes: DS Architects, Inc.
Beam Design Derek Slupka 7300 Dixie Hwy 2022A218
4/14/2022 1
4/14/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (75.00 + 3)] x (12 in./ft.)3 = 0.76 ft3
Volumespan = N[A x L] = 1 x [16.88 x 75.00] x (12 in./ft.)3 = 0.73 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.76 = 26.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.73 = 25.1 lbs
315 plf
210 plf
ws = 4.01 plf
6.25 ft.
6.50 ft.
1719.28 lbs
1719.28 lbs
4/14/2022 3
fb = = 979.6 psi
 fb = 979.6 psi < Fbx' = 1000.0 psi  (CSI = 0.98)   ➜  OK
4/14/2022 4
fv* = = 102.86 psi
 fv* = 102.86 psi < Fvx' = 180.00 psi  (CSI = 0.57)   ➜  OK
fv = = 146.95 psi
 fv = 146.95 psi < Fvx' = 180.00 psi  (CSI = 0.82)   ➜  OK
4/14/2022 5
ΔLL = = 0.04 in.
(L/d)LL = 75.00 / 0.04 = 2098
 ΔLL = 0.04 in = L/2098 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 75.00 / 0.06 = 1249
 ΔTL = 0.06 in = L/1249 < L/240   ➜  OK
fc⊥ = = 382.1 psi
 fc⊥ = 382.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.61)   ➜  OK
4/14/2022 6
