Beam Design - PATIO BEAM
Grade: SP No.1
Design Span (L): 18.25 ft.
Clear Span: 18.00 ft.
Total Span: 18.50 ft.
Quantity (N): 4
Live Load: 110 plf
Dead Load: 110 plf
Selfweight: 319.3 lbs
Dist. Selfweight: 17.50 plf
Total Weight: 323.7 lbs
Beam Design SUMAN LUITEL BRAE 2221012
4/13/2022 1
4/13/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (219.00 + 3)] x (12 in./ft.)3 = 8.67 ft3
Volumespan = N[A x L] = 4 x [16.88 x 219.00] x (12 in./ft.)3 = 8.55 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 8.67 = 323.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 8.55 = 319.3 lbs
Distributed Self Weight (ws) = = 17.50 plf
110 plf
110 plf
ws = 17.50 plf
18.25 ft.
18.00 ft.
18.50 ft.
2196.86 lbs
2196.86 lbs
4/13/2022 3
fb = = 937.5 psi
 fb = 937.5 psi < Fbx' = 1000.0 psi  (CSI = 0.94)   ➜  OK
4/13/2022 4
fv* = = 43.21 psi
 fv* = 43.21 psi < Fvx' = 175.00 psi  (CSI = 0.25)   ➜  OK
fv = = 48.16 psi
 fv = 48.16 psi < Fvx' = 175.00 psi  (CSI = 0.28)   ➜  OK
4/13/2022 5
ΔLL = = 0.24 in.
(L/d)LL = 219.00 / 0.24 = 909
 ΔLL = 0.24 in = L/909 < L/360   ➜  OK
ΔTL = = 0.52 in.
(L/d)TL = 219.00 / 0.52 = 421
 ΔTL = 0.52 in = L/421 < L/240   ➜  OK
fc⊥ = = 122.0 psi
 fc⊥ = 122.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.22)   ➜  OK
4/13/2022 6
