Species: Western Cedars
Grade: WC No.2
Design Span (L): 19.00 ft.
Clear Span: 18.00 ft.
Total Span: 20.00 ft.
Bearing (lb): 12 in.
Live Load: 1000 lbs
Dead Load: 200 lbs
Selfweight: 117.4 lbs
Dist. Selfweight: 6.18 plf
Total Weight: 123.6 lbs
Load Duration: 1.33
CM Wet Service Factor 1b 1 0.97 1c 0.67 0.9
CL Beam Stability Factor 0.814 - - - - -
Beam Design 2022A209
4/11/2022 1
WC No.2 700 425 155 425 650 1000000 370000 0.36
G = 0.36
4/11/2022 2
= 26.36 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (228.00 + 12)] x (12 in./ft.)3 = 4.69 ft3
Volumespan = N[A x L] = 2 x [16.88 x 228.00] x (12 in./ft.)3 = 4.45 ft3
Total Weight (WT) = ρw x Volumetotal = 26.36 x 4.69 = 123.6 lbs
Self Weight (WS) = ρw x Volumespan = 26.36 x 4.45 = 117.4 lbs
Distributed Self Weight (ws) = = 6.18 plf
1000 lbs
200 lbs
ws = 6.18 plf
19.00 ft.
18.00 ft.
661.79 lbs
661.79 lbs
4/11/2022 3
lu = Unbraced Length = 19.000 ft.
lu/d = = 20.27
le = 1.37lu + 3d = 1.37(228.0) + 3(11.25) = 346.11 in. = 28.84 ft.  (NDS Table 3.3.3)
Rb = = 20.80
 Rb = 20.80 < 50   ➜  OK
4/11/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 370000(0.9)(1)(1) = 333000 psi
FbE = = 923.64 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (700)(1.33)(1)(1)(1)(1)(1) = 931.00 psi
CL =   = 0.814
Fbx' = (700)(1.33)(1)(1)(0.814)(1)(1)(1) = 757.8 psi
fb = = 1133.8 psi
 fb = 1133.8 psi > Fbx' = 757.8 psi  (CSI = 1.50)   ➜  NG
Fvx' = (155)(1.33)(0.97)(1)(1) = 199.97 psi
fv* = = 29.02 psi
 fv* = 29.02 psi < Fvx' = 199.97 psi  (CSI = 0.15)   ➜  OK
fv = = 29.28 psi
 fv = 29.28 psi < Fvx' = 199.97 psi  (CSI = 0.15)   ➜  OK
4/11/2022 5
Ex' = Ex(CM)(Ct)(Ci) = 1000000(0.9)(1)(1) = 900000 psi
ΔLL =   =   = 0.77 in.
(L/d)LL = 228.00 / 0.77 = 296
 ΔLL = 0.77 in = L/296 < L/240   ➜  OK
ΔTL =   =   = 0.98 in.
(L/d)TL = 228.00 / 0.98 = 232
 ΔTL = 0.98 in = L/232 < L/180   ➜  OK
Ab = b x lb = 1.5 x 12 = 18.00 in2
fc⊥ = = 18.4 psi
 fc⊥ = 18.4 psi < Fc⊥x' = 284.75 psi  (CSI = 0.06)   ➜  OK
4/11/2022 6
