Grade: DF SS
Design Span (L): 15.67 ft.
Clear Span: 15.33 ft.
Total Span: 16.00 ft.
Bearing (lb): 4 in.
Selfweight: 125.6 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 128.3 lbs
Beam Design 2022A208
4/11/2022 1
4/11/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (188.00 + 4)] x (12 in./ft.)3 = 3.75 ft3
Volumespan = N[A x L] = 2 x [16.88 x 188.00] x (12 in./ft.)3 = 3.67 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.75 = 128.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.67 = 125.6 lbs
ws = 8.02 plf
15.67 ft.
15.33 ft.
1464.16 lbs
1464.16 lbs
4/11/2022 3
Fbx' = (1500)(1.00)(1)(1)(1)(1)(1)(1) = 1500.0 psi
fb = = 1064.8 psi
 fb = 1064.8 psi < Fbx' = 1500.0 psi  (CSI = 0.71)   ➜  OK
4/11/2022 4
fv* = = 56.09 psi
 fv* = 56.09 psi < Fvx' = 180.00 psi  (CSI = 0.31)   ➜  OK
fv = = 63.72 psi
 fv = 63.72 psi < Fvx' = 180.00 psi  (CSI = 0.35)   ➜  OK
4/11/2022 5
ΔLL = = 0.20 in.
(L/d)LL = 188.00 / 0.20 = 938
 ΔLL = 0.20 in = L/938 < L/360   ➜  OK
ΔTL = = 0.37 in.
(L/d)TL = 188.00 / 0.37 = 513
 ΔTL = 0.37 in = L/513 < L/240   ➜  OK
fc⊥ = = 122.0 psi
 fc⊥ = 122.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.20)   ➜  OK
4/11/2022 6
