Beam Design - Beam Calculation
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Selfweight: 44.4 lbs
Dist. Selfweight: 2.82 plf
Total Weight: 45.1 lbs
CL Beam Stability Factor 0.982 - - - - -
Beam Design Ron Sweet Jr. eastwood rd Sweet
4/10/2022 1
4/10/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (189.00 + 3)] x (12 in./ft.)3 = 1.21 ft3
Volumespan = N[A x L] = 1 x [10.88 x 189.00] x (12 in./ft.)3 = 1.19 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.21 = 45.1 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.19 = 44.4 lbs
Distributed Self Weight (ws) = = 2.82 plf
ws = 2.82 plf
15.75 ft.
15.50 ft.
1422.55 lbs
1422.55 lbs
4/10/2022 3
lu/d = = 3.31
Rb = = 12.62
 Rb = 12.62 < 50   ➜  OK
4/10/2022 4
FbE = = 3841.65 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (925)(1.15)(1)(1)(1)(1)(1) = 1063.75 psi
CL =   = 0.982
Fbx' = (925)(1.15)(1)(1)(0.982)(1)(1)(1) = 1044.3 psi
fb = = 5035.2 psi
 fb = 5035.2 psi > Fbx' = 1044.3 psi  (CSI = 4.82)   ➜  NG
fv* = = 178.33 psi
 fv* = 178.33 psi < Fvx' = 201.25 psi  (CSI = 0.89)   ➜  OK
fv = = 193.15 psi
 fv = 193.15 psi < Fvx' = 201.25 psi  (CSI = 0.96)   ➜  OK
4/10/2022 5
ΔLL = = 2.08 in.
(L/d)LL = 189.00 / 2.08 = 91
 ΔLL = 2.08 in = L/91 > L/360   ➜  NG
ΔTL = = 3.69 in.
(L/d)TL = 189.00 / 3.69 = 51
 ΔTL = 3.69 in = L/51 > L/240   ➜  NG
fc⊥ = = 316.1 psi
 fc⊥ = 316.1 psi < Fc⊥x' = 565.00 psi  (CSI = 0.56)   ➜  OK
4/10/2022 6
