Beam Design - Calculations for the city
Grade: 24F-E4 1.8E DF/DF
Size: 2.5 x 16.5
Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Dead Load: 590 plf
Selfweight: 104.0 lbs
Dist. Selfweight: 9.67 plf
Total Weight: 106.4 lbs
Beam Design Justin Hall 151
4/9/2022 1
b = 2.500 in.
d = 16.500 in.
A = 2.500 x 16.500 = 41.25 in.2
Sx = (2.500)(16.500)2/6 = 113.44 in.3
Sy = (2.500)2(16.500)/6 = 17.19 in.3
Ix = (2.500)(16.500)3/12 = 935.86 in.4
Iy = (2.500)3(16.500)/12 = 21.48 in.4
24F-E4 1.8E DF/DF 2400 1450 650 265 1800000 950000 1400 560 230 1700000 900000 1100 1700 0.5
4/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [41.25 x (129.00 + 3)] x (12 in./ft.)3 = 3.15 ft3
Volumespan = N[A x L] = 1 x [41.25 x 129.00] x (12 in./ft.)3 = 3.08 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.15 = 106.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.08 = 104.0 lbs
Distributed Self Weight (ws) = = 9.67 plf
590 plf
  ws = 9.67 plf
10.75 ft.
10.50 ft.
11.00 ft.
3848.19 lbs
3848.19 lbs
4/9/2022 3
fb = = 1069.2 psi
 fb = 1069.2 psi < Fbx' = 2760.0 psi  (CSI = 0.39)   ➜  OK
4/9/2022 4
fv* = = 101.77 psi
 fv* = 101.77 psi < Fvx' = 304.75 psi  (CSI = 0.33)   ➜  OK
fv = = 136.75 psi
 fv = 136.75 psi < Fvx' = 304.75 psi  (CSI = 0.45)   ➜  OK
4/9/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 129.00 / 0.02 = 7232
 ΔLL = 0.02 in = L/7232 < L/360   ➜  OK
ΔTL = = 0.12 in.
(L/d)TL = 129.00 / 0.12 = 1034
 ΔTL = 0.12 in = L/1034 < L/240   ➜  OK
fc⊥ = = 513.1 psi
 fc⊥ = 513.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.79)   ➜  OK
4/9/2022 6
