Beam Design - Calculations for the city
Size: 5.125 x 19.5
Design Span (L): 8.75 ft.
Clear Span: 8.50 ft.
Total Span: 9.00 ft.
Dead Load: 590 plf
Selfweight: 205.0 lbs
Dist. Selfweight: 23.43 plf
Total Weight: 210.9 lbs
Beam Design Justin Hall 151
4/9/2022 1
b = 5.125 in.
d = 19.500 in.
A = 5.125 x 19.500 = 99.94 in.2
Sx = (5.125)(19.500)2/6 = 324.80 in.3
Sy = (5.125)2(19.500)/6 = 85.36 in.3
Ix = (5.125)(19.500)3/12 = 3166.77 in.4
Iy = (5.125)3(19.500)/12 = 218.74 in.4
4/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [99.94 x (105.00 + 3)] x (12 in./ft.)3 = 6.25 ft3
Volumespan = N[A x L] = 1 x [99.94 x 105.00] x (12 in./ft.)3 = 6.07 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 6.25 = 210.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 6.07 = 205.0 lbs
Distributed Self Weight (ws) = = 23.43 plf
590 plf
  ws = 23.43 plf
8.75 ft.
8.50 ft.
9.00 ft.
3210.44 lbs
3210.44 lbs
4/9/2022 3
fb = = 252.3 psi
 fb = 252.3 psi < Fbx' = 2760.0 psi  (CSI = 0.09)   ➜  OK
4/9/2022 4
fv* = = 29.45 psi
 fv* = 29.45 psi < Fvx' = 304.75 psi  (CSI = 0.10)   ➜  OK
fv = = 46.85 psi
 fv = 46.85 psi < Fvx' = 304.75 psi  (CSI = 0.15)   ➜  OK
4/9/2022 5
ΔLL = = 0.00 in.
(L/d)LL = 105.00 / 0.00 = 45380
 ΔLL = 0.00 in = L/45380 < L/360   ➜  OK
ΔTL = = 0.02 in.
(L/d)TL = 105.00 / 0.02 = 6361
 ΔTL = 0.02 in = L/6361 < L/240   ➜  OK
fc⊥ = = 208.8 psi
 fc⊥ = 208.8 psi < Fc⊥x' = 650.00 psi  (CSI = 0.32)   ➜  OK
4/9/2022 6
