Beam Design - Calculations for the city
Size: 2.5 x 15
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Live Load: 50 plf
Dead Load: 600 plf
Selfweight: 129.7 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 131.9 lbs
Beam Design Justin Hall 150
4/9/2022 1
b = 2.500 in.
d = 15.000 in.
A = 2.500 x 15.000 = 37.50 in.2
Sx = (2.500)(15.000)2/6 = 93.75 in.3
Sy = (2.500)2(15.000)/6 = 15.63 in.3
Ix = (2.500)(15.000)3/12 = 703.13 in.4
Iy = (2.500)3(15.000)/12 = 19.53 in.4
4/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (177.00 + 3)] x (12 in./ft.)3 = 3.91 ft3
Volumespan = N[A x L] = 1 x [37.50 x 177.00] x (12 in./ft.)3 = 3.84 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.91 = 131.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.84 = 129.7 lbs
50 plf
600 plf
  ws = 8.79 plf
14.75 ft.
14.50 ft.
15.00 ft.
4940.94 lbs
4940.94 lbs
4/9/2022 3
fb = = 2293.3 psi
 fb = 2293.3 psi < Fbx' = 2760.0 psi  (CSI = 0.83)   ➜  OK
4/9/2022 4
fv* = = 161.40 psi
 fv* = 161.40 psi < Fvx' = 304.75 psi  (CSI = 0.53)   ➜  OK
fv = = 194.34 psi
 fv = 194.34 psi < Fvx' = 304.75 psi  (CSI = 0.64)   ➜  OK
4/9/2022 5
ΔLL = = 0.04 in.
(L/d)LL = 177.00 / 0.04 = 4207
 ΔLL = 0.04 in = L/4207 < L/360   ➜  OK
ΔTL = = 0.55 in.
(L/d)TL = 177.00 / 0.55 = 319
 ΔTL = 0.55 in = L/319 < L/240   ➜  OK
fc⊥ = = 658.8 psi
 fc⊥ = 658.8 psi > Fc⊥x' = 650.00 psi  (CSI = 1.01)   ➜  NG
4/9/2022 6
