Beam Design - Calculations for the city
Size: 2.5 x 6
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Dead Load: 720 plf
Selfweight: 51.9 lbs
Dist. Selfweight: 3.52 plf
Total Weight: 52.8 lbs
Beam Design Justin Hall 150
4/9/2022 1
b = 2.500 in.
d = 6.000 in.
A = 2.500 x 6.000 = 15.00 in.2
Sx = (2.500)(6.000)2/6 = 15.00 in.3
Sy = (2.500)2(6.000)/6 = 6.25 in.3
Ix = (2.500)(6.000)3/12 = 45.00 in.4
Iy = (2.500)3(6.000)/12 = 7.81 in.4
4/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [15.00 x (177.00 + 3)] x (12 in./ft.)3 = 1.56 ft3
Volumespan = N[A x L] = 1 x [15.00 x 177.00] x (12 in./ft.)3 = 1.54 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 1.56 = 52.8 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 1.54 = 51.9 lbs
720 plf
  ws = 3.52 plf
14.75 ft.
14.50 ft.
15.00 ft.
6176.38 lbs
6176.38 lbs
4/9/2022 3
fb = = 17916.6 psi
 fb = 17916.6 psi > Fbx' = 2760.0 psi  (CSI = 6.49)   ➜  NG
4/9/2022 4
fv* = = 566.17 psi
 fv* = 566.17 psi > Fvx' = 304.75 psi  (CSI = 1.86)   ➜  NG
fv = = 607.34 psi
 fv = 607.34 psi > Fvx' = 304.75 psi  (CSI = 1.99)   ➜  NG
4/9/2022 5
ΔLL = = 1.31 in.
(L/d)LL = 177.00 / 1.31 = 135
 ΔLL = 1.31 in = L/135 > L/180   ➜  NG
ΔTL = = 10.83 in.
(L/d)TL = 177.00 / 10.83 = 16
 ΔTL = 10.83 in = L/16 > L/120   ➜  NG
fc⊥ = = 823.5 psi
 fc⊥ = 823.5 psi > Fc⊥x' = 650.00 psi  (CSI = 1.27)   ➜  NG
4/9/2022 6
