Beam Design - Calculations for the city
Size: 5.5 x 28.5
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Dead Load: 720 plf
Selfweight: 542.1 lbs
Dist. Selfweight: 36.75 plf
Total Weight: 551.3 lbs
CV Volume Factor 0.943b - - - - -
Beam Design Justin Hall 150
4/9/2022 1
d = 28.500 in.
A = 5.500 x 28.500 = 156.75 in.2
Sx = (5.500)(28.500)2/6 = 744.56 in.3
Sy = (5.500)2(28.500)/6 = 143.69 in.3
Ix = (5.500)(28.500)3/12 = 10610.02 in.4
Iy = (5.500)3(28.500)/12 = 395.14 in.4
4/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [156.75 x (177.00 + 3)] x (12 in./ft.)3 = 16.33 ft3
Volumespan = N[A x L] = 1 x [156.75 x 177.00] x (12 in./ft.)3 = 16.06 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 16.33 = 551.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 16.06 = 542.1 lbs
Distributed Self Weight (ws) = = 36.75 plf
720 plf
  ws = 36.75 plf
14.75 ft.
14.50 ft.
15.00 ft.
6425.63 lbs
6425.63 lbs
4/9/2022 3
CV = = 0.943
CV = 0.943 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.943) = 2603.9 psi
fb = = 375.5 psi
 fb = 375.5 psi < Fbx' = 2603.9 psi  (CSI = 0.14)   ➜  OK
4/9/2022 4
fv* = = 40.99 psi
 fv* = 40.99 psi < Fvx' = 304.75 psi  (CSI = 0.13)   ➜  OK
fv = = 60.46 psi
 fv = 60.46 psi < Fvx' = 304.75 psi  (CSI = 0.20)   ➜  OK
4/9/2022 5
ΔLL = = 0.01 in.
(L/d)LL = 177.00 / 0.01 = 31740
 ΔLL = 0.01 in = L/31740 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 177.00 / 0.05 = 3705
 ΔTL = 0.05 in = L/3705 < L/240   ➜  OK
fc⊥ = = 389.4 psi
 fc⊥ = 389.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.60)   ➜  OK
4/9/2022 6
