Beam Design - 1
Size: 5.5 x 24
Design Span (L): 25.54 ft.
Clear Span: 25.08 ft.
Total Span: 26.00 ft.
Bearing (lb): 5.5 in.
Live Load: 510 plf
Dead Load: 90 plf
Selfweight: 790.5 lbs
Dist. Selfweight: 30.95 plf
Total Weight: 804.7 lbs
CV Volume Factor 0.909b - - - - -
Beam Design Meadow Murdoch 1
1/12/2022 1
d = 24.000 in.
A = 5.500 x 24.000 = 132.00 in.2
Sx = (5.500)(24.000)2/6 = 528.00 in.3
Sy = (5.500)2(24.000)/6 = 121.00 in.3
Ix = (5.500)(24.000)3/12 = 6336.00 in.4
Iy = (5.500)3(24.000)/12 = 332.75 in.4
1/12/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [132.00 x (306.50 + 5.5)] x (12 in./ft.)3 = 23.83 ft3
Volumespan = N[A x L] = 1 x [132.00 x 306.50] x (12 in./ft.)3 = 23.41 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 23.83 = 804.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 23.41 = 790.5 lbs
Distributed Self Weight (ws) = = 30.95 plf
510 plf
90 plf
  ws = 30.95 plf
25.54 ft.
25.08 ft.
26.00 ft.
8202.43 lbs
8202.43 lbs
1/12/2022 3
lu/d = = 1.00
Rb = = 6.26
 Rb = 6.26 < 50   ➜  OK
1/12/2022 4
FbE = = 26003.74 psi
CL =   = 0.994
CV = = 0.909
CV = 0.909 < CL = 0.994
Fbx' = (2400)(1.15)(1)(1)(0.909) = 2507.5 psi
fb = = 1169.4 psi
 fb = 1169.4 psi < Fbx' = 2507.5 psi  (CSI = 0.47)   ➜  OK
fv* = = 77.23 psi
1/12/2022 5
 fv* = 77.23 psi < Fvx' = 304.75 psi  (CSI = 0.25)   ➜  OK
fv = = 91.57 psi
 fv = 91.57 psi < Fvx' = 304.75 psi  (CSI = 0.30)   ➜  OK
ΔLL = = 0.43 in.
(L/d)LL = 306.50 / 0.43 = 716
 ΔLL = 0.43 in = L/716 < L/360   ➜  OK
ΔTL = = 0.53 in.
(L/d)TL = 306.50 / 0.53 = 579
 ΔTL = 0.53 in = L/579 < L/240   ➜  OK
1/12/2022 6
fc⊥ = = 271.2 psi
 fc⊥ = 271.2 psi < Fc⊥x' = 650.00 psi  (CSI = 0.42)   ➜  OK
1/12/2022 7
