Beam Design - Calculations for the city
Size: 12.25 x 52.5
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Live Load: 50 plf
Dead Load: 3000 plf
Selfweight: 2224.0 lbs
Dist. Selfweight: 150.78 plf
Total Weight: 2261.7 lbs
CV Volume Factor 0.819b - - - - -
Beam Design Justin Hall 150
4/9/2022 1
b = 12.250 in.
d = 52.500 in.
A = 12.250 x 52.500 = 643.13 in.2
Sx = (12.250)(52.500)2/6 = 5627.34 in.3
Sy = (12.250)2(52.500)/6 = 1313.05 in.3
Ix = (12.250)(52.500)3/12 = 147717.77 in.4
Iy = (12.250)3(52.500)/12 = 8042.41 in.4
4/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [643.13 x (177.00 + 3)] x (12 in./ft.)3 = 66.99 ft3
Volumespan = N[A x L] = 1 x [643.13 x 177.00] x (12 in./ft.)3 = 65.88 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 66.99 = 2261.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 65.88 = 2224.0 lbs
Distributed Self Weight (ws) = = 150.78 plf
50 plf
3000 plf
  ws = 150.78 plf
14.75 ft.
14.50 ft.
15.00 ft.
24005.87 lbs
24005.87 lbs
4/9/2022 3
CV = = 0.819
CV = 0.819 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.819) = 2261.0 psi
fb = = 185.6 psi
 fb = 185.6 psi < Fbx' = 2261.0 psi  (CSI = 0.08)   ➜  OK
4/9/2022 4
fv* = = 22.40 psi
 fv* = 22.40 psi < Fvx' = 304.75 psi  (CSI = 0.07)   ➜  OK
fv = = 55.06 psi
 fv = 55.06 psi < Fvx' = 304.75 psi  (CSI = 0.18)   ➜  OK
4/9/2022 5
ΔLL = = 0.00 in.
(L/d)LL = 177.00 / 0.00 = 883808
 ΔLL = 0.00 in = L/883808 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 177.00 / 0.01 = 13806
 ΔTL = 0.01 in = L/13806 < L/240   ➜  OK
Ab = b x lb = 12.25 x 3 = 36.75 in2
fc⊥ = = 653.2 psi
 fc⊥ = 653.2 psi > Fc⊥x' = 650.00 psi  (CSI = 1.00)   ➜  NG
4/9/2022 6
