Beam Design - Calculations for the city
Size: 5.5 x 7.5
Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Live Load: 50 plf
Dead Load: 5000 plf
Selfweight: 142.6 lbs
Dist. Selfweight: 9.67 plf
Total Weight: 145.1 lbs
Beam Design Justin Hall 150
4/9/2022 1
d = 7.500 in.
A = 5.500 x 7.500 = 41.25 in.2
Sx = (5.500)(7.500)2/6 = 51.56 in.3
Sy = (5.500)2(7.500)/6 = 37.81 in.3
Ix = (5.500)(7.500)3/12 = 193.36 in.4
Iy = (5.500)3(7.500)/12 = 103.98 in.4
4/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [41.25 x (177.00 + 3)] x (12 in./ft.)3 = 4.30 ft3
Volumespan = N[A x L] = 1 x [41.25 x 177.00] x (12 in./ft.)3 = 4.23 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 4.30 = 145.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 4.23 = 142.6 lbs
Distributed Self Weight (ws) = = 9.67 plf
50 plf
5000 plf
  ws = 9.67 plf
14.75 ft.
14.50 ft.
15.00 ft.
37947.53 lbs
37947.53 lbs
4/9/2022 3
fb = = 32023.1 psi
 fb = 32023.1 psi > Fbx' = 2760.0 psi  (CSI = 11.60)   ➜  NG
4/9/2022 4
fv* = = 1241.92 psi
 fv* = 1241.92 psi > Fvx' = 304.75 psi  (CSI = 4.08)   ➜  NG
fv = = 1356.91 psi
 fv = 1356.91 psi > Fvx' = 304.75 psi  (CSI = 4.45)   ➜  NG
4/9/2022 5
ΔLL = = 0.15 in.
(L/d)LL = 177.00 / 0.15 = 1157
 ΔLL = 0.15 in = L/1157 < L/180   ➜  OK
ΔTL = = 15.48 in.
(L/d)TL = 177.00 / 15.48 = 11
 ΔTL = 15.48 in = L/11 > L/120   ➜  NG
fc⊥ = = 2299.9 psi
 fc⊥ = 2299.9 psi > Fc⊥x' = 650.00 psi  (CSI = 3.54)   ➜  NG
4/9/2022 6
