Design Span (L): 2.75 ft.
Clear Span: 2.50 ft.
Total Span: 3.00 ft.
Live Load: 695 plf
Dead Load: 0 plf
Selfweight: 7.8 lbs
Dist. Selfweight: 2.82 plf
Total Weight: 8.5 lbs
Load Duration: 1.25
CL Beam Stability Factor 0.960 - - - - -
Beam Design 2022A196
4/8/2022 1
4/8/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (33.00 + 3)] x (12 in./ft.)3 = 0.23 ft3
Volumespan = N[A x L] = 1 x [10.88 x 33.00] x (12 in./ft.)3 = 0.21 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.23 = 8.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.21 = 7.8 lbs
Distributed Self Weight (ws) = = 2.82 plf
695 plf
0 plf
ws = 2.82 plf
2.75 ft.
2.50 ft.
3.00 ft.
1046.73 lbs
1046.73 lbs
4/8/2022 3
lu = Unbraced Length = 2.750 ft.
lu/d = = 4.55
le = 2.06lu = 2.06(33.0) = 67.98 in. = 5.67 ft.  (NDS Table 3.3.3)
Rb = = 14.80
 Rb = 14.80 < 50   ➜  OK
4/8/2022 4
FbE = = 2793.93 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (925)(1.25)(1)(1)(1)(1)(1.15) = 1329.69 psi
CL =   = 0.960
Fbx' = (925)(1.25)(1)(1)(0.960)(1)(1)(1.15) = 1276.0 psi
fb = = 602.4 psi
 fb = 602.4 psi < Fbx' = 1276.0 psi  (CSI = 0.47)   ➜  OK
Fvx' = (175)(1.25)(1)(1)(1) = 218.75 psi
fv* = = 74.19 psi
 fv* = 74.19 psi < Fvx' = 218.75 psi  (CSI = 0.34)   ➜  OK
fv = = 132.35 psi
 fv = 132.35 psi < Fvx' = 218.75 psi  (CSI = 0.61)   ➜  OK
4/8/2022 5
ΔLL = = 0.01 in.
(L/d)LL = 33.00 / 0.01 = 2461
 ΔLL = 0.01 in = L/2461 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 33.00 / 0.01 = 2451
 ΔTL = 0.01 in = L/2451 < L/240   ➜  OK
fc⊥ = = 232.6 psi
 fc⊥ = 232.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.41)   ➜  OK
4/8/2022 6
