Grade: DF SS
Size: 4 x 10
Design Span (L): 6.83 ft.
Clear Span: 6.67 ft.
Total Span: 7.00 ft.
Bearing (lb): 2 in.
Live Load: 0 plf
Dead Load: 563 plf
Selfweight: 52.5 lbs
Dist. Selfweight: 7.69 plf
Total Weight: 53.8 lbs
Orientation: Horizontal
Beam Design 2022A194
4/6/2022 1
4/6/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (82.00 + 2)] x (12 in./ft.)3 = 1.57 ft3
Volumespan = N[A x L] = 1 x [32.38 x 82.00] x (12 in./ft.)3 = 1.54 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.57 = 53.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.54 = 52.5 lbs
0 plf
563 plf
ws = 7.69 plf
6.83 ft.
6.67 ft.
7.00 ft.
1997.32 lbs
1997.32 lbs
4/6/2022 3
Fby' = (1500)(0.9)(1)(1)(1)(1.2)(1.1)(1)(1) = 1782.0 psi
fb = = 2116.4 psi
 fb = 2116.4 psi > Fby' = 1782.0 psi  (CSI = 1.19)   ➜  NG
4/6/2022 4
Fvy' = (180)(0.9)(1)(1)(1) = 162.00 psi
fv* = = 82.62 psi
 fv* = 82.62 psi < Fvy' = 162.00 psi  (CSI = 0.51)   ➜  OK
fv = = 90.34 psi
 fv = 90.34 psi < Fvy' = 162.00 psi  (CSI = 0.56)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1900000(1)(1)(1) = 1900000 psi
4/6/2022 5
ΔLL = = 0.00 in.
(L/d)LL = 82.00 / 0.00 = ∞
ΔTL = = 0.45 in.
(L/d)TL = 82.00 / 0.45 = 184
 ΔTL = 0.45 in = L/184 < L/120   ➜  OK
Ab = d x lb = 9.25 x 2 = 18.50 in2
fc⊥ = = 108.0 psi
 fc⊥ = 108.0 psi < Fc⊥y' = 625.00 psi  (CSI = 0.17)   ➜  OK
4/6/2022 6
