Design Span (L): 4.75 ft.
Clear Span: 4.50 ft.
Total Span: 5.00 ft.
Live Load: 2000 lbs
Dead Load: 100 lbs
Selfweight: 20.3 lbs
Dist. Selfweight: 4.28 plf
Total Weight: 21.4 lbs
Load Duration: 1.25
Orientation: Horizontal
Beam Design 2022A190
4/1/2022 1
4/1/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (57.00 + 3)] x (12 in./ft.)3 = 0.57 ft3
Volumespan = N[A x L] = 2 x [8.25 x 57.00] x (12 in./ft.)3 = 0.54 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.57 = 21.4 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.54 = 20.3 lbs
Distributed Self Weight (ws) = = 4.28 plf
2000 lbs
100 lbs
ws = 4.28 plf
4.75 ft.
4.50 ft.
5.00 ft.
1060.69 lbs
1060.69 lbs
4/1/2022 3
Fby' = (1000)(1.25)(1)(1)(1)(1)(1.15)(1)(1) = 1437.5 psi
fb = = 7289.6 psi
 fb = 7289.6 psi > Fby' = 1437.5 psi  (CSI = 5.07)   ➜  NG
4/1/2022 4
Fvy' = (175)(1.25)(1)(1)(1) = 218.75 psi
fv* = = 96.33 psi
 fv* = 96.33 psi < Fvy' = 218.75 psi  (CSI = 0.44)   ➜  OK
fv = = 96.38 psi
 fv = 96.38 psi < Fvy' = 218.75 psi  (CSI = 0.44)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1400000(1)(1)(1) = 1400000 psi
4/1/2022 5
ΔLL =   =   = 1.78 in.
(L/d)LL = 57.00 / 1.78 = 32
 ΔLL = 1.78 in = L/32 > L/180   ➜  NG
ΔTL =   =   = 1.88 in.
(L/d)TL = 57.00 / 1.88 = 30
 ΔTL = 1.88 in = L/30 > L/120   ➜  NG
Fc⊥y' = (565)(1)(1)(1) = 565.00 psi
Ab = d x lb = 5.5 x 3 = 16.50 in2
fc⊥ = = 32.1 psi
 fc⊥ = 32.1 psi < Fc⊥y' = 565.00 psi  (CSI = 0.06)   ➜  OK
4/1/2022 6
