Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 2000 lbs
Dead Load: 100 lbs
Selfweight: 27.9 lbs
Dist. Selfweight: 3.60 plf
Total Weight: 28.8 lbs
Load Duration: 1.25
CL Beam Stability Factor 0.800 - - - - -
Beam Design 2022A189
4/1/2022 1
4/1/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (93.00 + 3)] x (12 in./ft.)3 = 0.77 ft3
Volumespan = N[A x L] = 1 x [13.88 x 93.00] x (12 in./ft.)3 = 0.75 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.77 = 28.8 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.75 = 27.9 lbs
2000 lbs
100 lbs
ws = 3.60 plf
7.75 ft.
7.50 ft.
1064.39 lbs
1064.39 lbs
4/1/2022 3
lu = Unbraced Length = 7.750 ft.
lu/d = = 10.05
le = 1.37lu + 3d = 1.37(93.0) + 3(9.25) = 155.16 in. = 12.93 ft.  (NDS Table 3.3.3)
Rb = = 25.26
 Rb = 25.26 < 50   ➜  OK
4/1/2022 4
FbE = = 959.43 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (800)(1.25)(1)(1)(1)(1)(1) = 1000.00 psi
CL =   = 0.800
Fbx' = (800)(1.25)(1)(1)(0.800)(1)(1)(1) = 799.7 psi
fb = = 2297.7 psi
 fb = 2297.7 psi > Fbx' = 799.7 psi  (CSI = 2.87)   ➜  NG
Fvx' = (175)(1.25)(1)(1)(1) = 218.75 psi
fv* = = 114.72 psi
 fv* = 114.72 psi < Fvx' = 218.75 psi  (CSI = 0.52)   ➜  OK
fv = = 115.02 psi
 fv = 115.02 psi < Fvx' = 218.75 psi  (CSI = 0.53)   ➜  OK
4/1/2022 5
ΔLL =   =   = 0.24 in.
(L/d)LL = 93.00 / 0.24 = 384
 ΔLL = 0.24 in = L/384 < L/180   ➜  OK
ΔTL =   =   = 0.26 in.
(L/d)TL = 93.00 / 0.26 = 363
 ΔTL = 0.26 in = L/363 < L/120   ➜  OK
fc⊥ = = 236.5 psi
 fc⊥ = 236.5 psi < Fc⊥x' = 565.00 psi  (CSI = 0.42)   ➜  OK
4/1/2022 6
