Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 100 lbs
Dead Load: 2000 lbs
Selfweight: 55.8 lbs
Dist. Selfweight: 7.19 plf
Total Weight: 57.6 lbs
Load Duration: 1.25
Beam Design 2022A187
4/1/2022 1
4/1/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (93.00 + 3)] x (12 in./ft.)3 = 1.54 ft3
Volumespan = N[A x L] = 2 x [13.88 x 93.00] x (12 in./ft.)3 = 1.49 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.54 = 57.6 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.49 = 55.8 lbs
100 lbs
2000 lbs
ws = 7.19 plf
7.75 ft.
7.50 ft.
1078.78 lbs
1078.78 lbs
4/1/2022 3
lu = Unbraced Length = 7.750 ft.
lu/d = = 10.05
le = 1.37lu + 3d = 1.37(93.0) + 3(9.25) = 155.16 in. = 12.93 ft.  (NDS Table 3.3.3)
Rb = = 12.63
 Rb = 12.63 < 50   ➜  OK
4/1/2022 4
FbE = = 3837.71 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (800)(1.25)(1)(1)(1)(1)(1) = 1000.00 psi
CL =   = 0.983
Fbx' = (800)(1.25)(1)(1)(0.983)(1)(1)(1) = 983.1 psi
fb = = 1156.4 psi
 fb = 1156.4 psi > Fbx' = 983.1 psi  (CSI = 1.18)   ➜  NG
Fvx' = (175)(1.25)(1)(1)(1) = 218.75 psi
fv* = = 57.96 psi
 fv* = 57.96 psi < Fvx' = 218.75 psi  (CSI = 0.26)   ➜  OK
fv = = 58.26 psi
 fv = 58.26 psi < Fvx' = 218.75 psi  (CSI = 0.27)   ➜  OK
4/1/2022 5
ΔLL =   =   = 0.01 in.
(L/d)LL = 93.00 / 0.01 = 15373
 ΔLL = 0.01 in = L/15373 < L/180   ➜  OK
ΔTL =   =   = 0.13 in.
(L/d)TL = 93.00 / 0.13 = 720
 ΔTL = 0.13 in = L/720 < L/120   ➜  OK
fc⊥ = = 119.9 psi
 fc⊥ = 119.9 psi < Fc⊥x' = 565.00 psi  (CSI = 0.21)   ➜  OK
4/1/2022 6
