Size: 2.5 x 12
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Quantity (N): 6
Live Load: 80 plf
Dead Load: 60 plf
Selfweight: 601.4 lbs
Dist. Selfweight: 42.20 plf
Total Weight: 611.9 lbs
Beam Design Barth
3/31/2022 1
b = 2.500 in.
A = 2.500 x 12.000 = 30.00 in.2
Sx = (2.500)(12.000)2/6 = 60.00 in.3
Sy = (2.500)2(12.000)/6 = 12.50 in.3
Ix = (2.500)(12.000)3/12 = 360.00 in.4
Iy = (2.500)3(12.000)/12 = 15.63 in.4
Beam Design Barth
3/31/2022 2
Volumetotal = N[A x (L + lb)] = 6 x [30.00 x (171.00 + 3)] x (12 in./ft.)3 = 18.13 ft3
Volumespan = N[A x L] = 6 x [30.00 x 171.00] x (12 in./ft.)3 = 17.81 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 18.13 = 611.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 17.81 = 601.4 lbs
Distributed Self Weight (ws) = = 42.20 plf
80 plf
60 plf
  ws = 42.20 plf
14.25 ft.
14.50 ft.
1320.96 lbs
1320.96 lbs
Beam Design Barth
3/31/2022 3
fb = = 154.2 psi
 fb = 154.2 psi < Fbx' = 2400.0 psi  (CSI = 0.06)   ➜  OK
Beam Design Barth
3/31/2022 4
fv* = = 9.30 psi
 fv* = 9.30 psi < Fvx' = 265.00 psi  (CSI = 0.04)   ➜  OK
fv = = 10.82 psi
 fv = 10.82 psi < Fvx' = 265.00 psi  (CSI = 0.04)   ➜  OK
Beam Design Barth
3/31/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 171.00 / 0.02 = 8958
 ΔLL = 0.02 in = L/8958 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 171.00 / 0.04 = 3933
 ΔTL = 0.04 in = L/3933 < L/240   ➜  OK
fc⊥ = = 29.4 psi
 fc⊥ = 29.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.05)   ➜  OK
Beam Design Barth
3/31/2022 6
