Grade: 24F-V5 1.7E DF/HF
Size: 8.75 x 46.5
Design Span (L): 73.75 ft.
Clear Span: 73.50 ft.
Total Span: 74.00 ft.
Live Load: 16 plf
Dead Load: 13 plf
Selfweight: 7035.2 lbs
Dist. Selfweight: 95.39 plf
Total Weight: 7059.1 lbs
CV Volume Factor 0.730b - - - - -
Beam Design 2022A185
3/31/2022 1
b = 8.750 in.
d = 46.500 in.
A = 8.750 x 46.500 = 406.88 in.2
Sx = (8.750)(46.500)2/6 = 3153.28 in.3
Sy = (8.750)2(46.500)/6 = 593.36 in.3
Ix = (8.750)(46.500)3/12 = 73313.79 in.4
Iy = (8.750)3(46.500)/12 = 2595.95 in.4
24F-V5 1.7E DF/HF 2400 1600 650 215 1700000 900000 1350 375 200 1500000 790000 1100 1450 0.5
3/31/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [406.88 x (885.00 + 3)] x (12 in./ft.)3 = 209.09 ft3
Volumespan = N[A x L] = 1 x [406.88 x 885.00] x (12 in./ft.)3 = 208.38 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 209.09 = 7059.1 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 208.38 = 7035.2 lbs
Distributed Self Weight (ws) = = 95.39 plf
16 plf
13 plf
  ws = 95.39 plf
73.75 ft.
73.50 ft.
74.00 ft.
4602.54 lbs
4602.54 lbs
3/31/2022 3
CV = = 0.730
CV = 0.730 < CL = 1
Fbx' = (2400)(1.00)(1)(1)(0.730) = 1752.3 psi
fb = = 321.8 psi
 fb = 321.8 psi < Fbx' = 1752.3 psi  (CSI = 0.18)   ➜  OK
3/31/2022 4
Fvx' = (215)(1.00)(1)(1) = 215.00 psi
fv* = = 15.13 psi
 fv* = 15.13 psi < Fvx' = 215.00 psi  (CSI = 0.07)   ➜  OK
fv = = 16.91 psi
 fv = 16.91 psi < Fvx' = 215.00 psi  (CSI = 0.08)   ➜  OK
Ex' = Ex(CM)(Ct) = 1700000(1)(1) = 1700000 psi
3/31/2022 5
ΔLL = = 0.09 in.
(L/d)LL = 885.00 / 0.09 = 10357
 ΔLL = 0.09 in = L/10357 < L/240   ➜  OK
ΔTL = = 0.66 in.
(L/d)TL = 885.00 / 0.66 = 1332
 ΔTL = 0.66 in = L/1332 < L/180   ➜  OK
Ab = b x lb = 8.75 x 3 = 26.25 in2
fc⊥ = = 175.3 psi
 fc⊥ = 175.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.27)   ➜  OK
3/31/2022 6
