Design Span (L): 12.00 ft.
Clear Span: 11.75 ft.
Total Span: 12.25 ft.
Live Load: 100 lbs
Dead Load: 75 lbs
Selfweight: 51.3 lbs
Dist. Selfweight: 4.28 plf
Total Weight: 52.4 lbs
Beam Design 2022A183
3/31/2022 1
3/31/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (144.00 + 3)] x (12 in./ft.)3 = 1.40 ft3
Volumespan = N[A x L] = 2 x [8.25 x 144.00] x (12 in./ft.)3 = 1.38 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.40 = 52.4 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.38 = 51.3 lbs
Distributed Self Weight (ws) = = 4.28 plf
100 lbs
75 lbs
ws = 4.28 plf
12.25 ft.
113.70 lbs
113.70 lbs
3/31/2022 3
fb = = 477.6 psi
 fb = 477.6 psi < Fbx' = 1000.0 psi  (CSI = 0.48)   ➜  OK
3/31/2022 4
fv* = = 10.11 psi
 fv* = 10.11 psi < Fvx' = 175.00 psi  (CSI = 0.06)   ➜  OK
fv = = 10.29 psi
 fv = 10.29 psi < Fvx' = 175.00 psi  (CSI = 0.06)   ➜  OK
3/31/2022 5
ΔLL =   =   = 0.11 in.
(L/d)LL = 144.00 / 0.11 = 1348
 ΔLL = 0.11 in = L/1348 < L/360   ➜  OK
ΔTL =   =   = 0.22 in.
(L/d)TL = 144.00 / 0.22 = 651
 ΔTL = 0.22 in = L/651 < L/240   ➜  OK
fc⊥ = = 12.6 psi
 fc⊥ = 12.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.02)   ➜  OK
3/31/2022 6
