Grade: SPF SS
Design Span (L): 11.77 ft.
Clear Span: 11.54 ft.
Bearing (lb): 2.75 in.
Selfweight: 99.0 lbs
Dist. Selfweight: 8.41 plf
Total Weight: 100.9 lbs
Beam Design 2022A182
3/31/2022 1
3/31/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (141.25 + 2.75)] x (12 in./ft.)3 = 3.47 ft3
Volumespan = N[A x L] = 3 x [13.88 x 141.25] x (12 in./ft.)3 = 3.40 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 3.47 = 100.9 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 3.40 = 99.0 lbs
Distributed Self Weight (ws) = = 8.41 plf
ws = 8.41 plf
11.77 ft.
11.54 ft.
1100.48 lbs
1100.48 lbs
3/31/2022 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.1)(1)(1) = 1581.3 psi
fb = = 594.0 psi
 fb = 594.0 psi < Fbx' = 1581.3 psi  (CSI = 0.38)   ➜  OK
3/31/2022 4
fv* = = 33.80 psi
 fv* = 33.80 psi < Fvx' = 155.25 psi  (CSI = 0.22)   ➜  OK
fv = = 38.90 psi
 fv = 38.90 psi < Fvx' = 155.25 psi  (CSI = 0.25)   ➜  OK
3/31/2022 5
ΔLL = = 0.10 in.
(L/d)LL = 141.25 / 0.10 = 1456
 ΔLL = 0.10 in = L/1456 < L/360   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 141.25 / 0.18 = 794
 ΔTL = 0.18 in = L/794 < L/240   ➜  OK
fc⊥ = = 88.9 psi
 fc⊥ = 88.9 psi < Fc⊥x' = 425.00 psi  (CSI = 0.21)   ➜  OK
3/31/2022 6
