Grade: 24F-V3 1.8E SP/SP
Size: 5.5 x 13.75
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 160 plf
Dead Load: 240 plf
Selfweight: 266.4 lbs
Dist. Selfweight: 19.37 plf
Total Weight: 271.2 lbs
Load Duration: 1.25
CL Beam Stability Factor 0.968 - - - - -
Beam Design 2022A178
3/28/2022 1
d = 13.750 in.
A = 5.500 x 13.750 = 75.63 in.2
Sx = (5.500)(13.750)2/6 = 173.31 in.3
Sy = (5.500)2(13.750)/6 = 69.32 in.3
Ix = (5.500)(13.750)3/12 = 1191.49 in.4
Iy = (5.500)3(13.750)/12 = 190.64 in.4
3/28/2022 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [75.63 x (165.00 + 3)] x (12 in./ft.)3 = 7.35 ft3
Volumespan = N[A x L] = 1 x [75.63 x 165.00] x (12 in./ft.)3 = 7.22 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 7.35 = 271.2 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 7.22 = 266.4 lbs
Distributed Self Weight (ws) = = 19.37 plf
160 plf
240 plf
  ws = 19.37 plf
13.75 ft.
13.50 ft.
2935.61 lbs
2935.61 lbs
3/28/2022 3
lu = Unbraced Length = 13.750 ft.
lu/d = = 12.00
le = 1.63lu + 3d = 1.63(165.0) + 3(13.75) = 310.20 in. = 25.85 ft.  (NDS Table 3.3.3)
Rb = = 11.87
 Rb = 11.87 < 50   ➜  OK
3/28/2022 4
FbE = = 7234.04 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.25)(1)(1) = 3000.00 psi
CL =   = 0.968
CL = 0.968 < CV = 1.0
Fbx' = (2400)(1.25)(1)(1)(0.968) = 2902.7 psi
fb = = 686.2 psi
 fb = 686.2 psi < Fbx' = 2902.7 psi  (CSI = 0.24)   ➜  OK
Fvx' = (300)(1.25)(1)(1) = 375.00 psi
fv* = = 47.66 psi
3/28/2022 5
 fv* = 47.66 psi < Fvx' = 375.00 psi  (CSI = 0.13)   ➜  OK
fv = = 57.19 psi
 fv = 57.19 psi < Fvx' = 375.00 psi  (CSI = 0.15)   ➜  OK
ΔLL = = 0.06 in.
(L/d)LL = 165.00 / 0.06 = 2750
 ΔLL = 0.06 in = L/2750 < L/360   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 165.00 / 0.16 = 1049
 ΔTL = 0.16 in = L/1049 < L/240   ➜  OK
3/28/2022 6
fc⊥ = = 177.9 psi
 fc⊥ = 177.9 psi < Fc⊥x' = 740.00 psi  (CSI = 0.24)   ➜  OK
3/28/2022 7
