Grade: 24F-V8 1.8E DF/DF
Size: 5.5 x 13.5
Design Span (L): 13.75 ft.
Clear Span: 13.50 ft.
Total Span: 14.00 ft.
Live Load: 200 plf
Dead Load: 200 plf
Selfweight: 239.4 lbs
Dist. Selfweight: 17.41 plf
Total Weight: 243.7 lbs
Load Duration: 1.33
CL Beam Stability Factor 0.965 - - - - -
Beam Design 2022A175
3/28/2022 1
d = 13.500 in.
3/28/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [74.25 x (165.00 + 3)] x (12 in./ft.)3 = 7.22 ft3
Volumespan = N[A x L] = 1 x [74.25 x 165.00] x (12 in./ft.)3 = 7.09 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.22 = 243.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.09 = 239.4 lbs
200 plf
200 plf
  ws = 17.41 plf
13.75 ft.
13.50 ft.
2921.86 lbs
2921.86 lbs
3/28/2022 3
lu = Unbraced Length = 13.750 ft.
lu/d = = 12.22
le = 1.63lu + 3d = 1.63(165.0) + 3(13.5) = 309.45 in. = 25.79 ft.  (NDS Table 3.3.3)
Rb = = 11.75
 Rb = 11.75 < 50   ➜  OK
3/28/2022 4
FbE = = 7385.86 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.33)(1)(1) = 3192.00 psi
CL =   = 0.965
CL = 0.965 < CV = 1.0
Fbx' = (2400)(1.33)(1)(1)(0.965) = 3081.7 psi
fb = = 708.6 psi
 fb = 708.6 psi < Fbx' = 3081.7 psi  (CSI = 0.23)   ➜  OK
Fvx' = (265)(1.33)(1)(1) = 352.45 psi
fv* = = 48.49 psi
3/28/2022 5
 fv* = 48.49 psi < Fvx' = 352.45 psi  (CSI = 0.14)   ➜  OK
fv = = 57.97 psi
 fv = 57.97 psi < Fvx' = 352.45 psi  (CSI = 0.16)   ➜  OK
ΔLL = = 0.08 in.
(L/d)LL = 165.00 / 0.08 = 2082
 ΔLL = 0.08 in = L/2082 < L/360   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 165.00 / 0.17 = 998
 ΔTL = 0.17 in = L/998 < L/240   ➜  OK
3/28/2022 6
fc⊥ = = 177.1 psi
 fc⊥ = 177.1 psi < Fc⊥x' = 650.00 psi  (CSI = 0.27)   ➜  OK
3/28/2022 7
