Size: 4 x 4
Design Span (L): 9.40 ft.
Clear Span: 9.25 ft.
Total Span: 9.54 ft.
Bearing (lb): 1.75 in.
Live Load: 50 plf
Dead Load: 10 plf
Selfweight: 29.8 lbs
Dist. Selfweight: 3.18 plf
Total Weight: 30.3 lbs
Beam Design 2022A172
3/24/2022 1
d = 3.500 in.
SP No.2 1100 675 175 565 1450 1400000 510000 0.55
3/24/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (112.75 + 1.75)] x (12 in./ft.)3 = 0.81 ft3
Volumespan = N[A x L] = 1 x [12.25 x 112.75] x (12 in./ft.)3 = 0.80 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.81 = 30.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.80 = 29.8 lbs
Distributed Self Weight (ws) = = 3.18 plf
50 plf
10 plf
ws = 3.18 plf
9.40 ft.
9.25 ft.
9.54 ft.
301.41 lbs
301.41 lbs
3/24/2022 3
Fbx' = (1100)(1.00)(1)(1)(1)(1)(1)(1.15) = 1265.0 psi
fb = = 1170.8 psi
 fb = 1170.8 psi < Fbx' = 1265.0 psi  (CSI = 0.93)   ➜  OK
3/24/2022 4
fv* = = 34.09 psi
 fv* = 34.09 psi < Fvx' = 175.00 psi  (CSI = 0.19)   ➜  OK
fv = = 36.34 psi
 fv = 36.34 psi < Fvx' = 175.00 psi  (CSI = 0.21)   ➜  OK
3/24/2022 5
ΔLL = = 0.50 in.
(L/d)LL = 112.75 / 0.50 = 225
 ΔLL = 0.50 in = L/225 > L/360   ➜  NG
ΔTL = = 0.63 in.
(L/d)TL = 112.75 / 0.63 = 178
 ΔTL = 0.63 in = L/178 > L/240   ➜  NG
Ab = b x lb = 3.5 x 1.75 = 6.13 in2
fc⊥ = = 49.2 psi
 fc⊥ = 49.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.09)   ➜  OK
3/24/2022 6
