Beam Design - Concept Renov.
Size: 4 x 4
Design Span (L): 2.91 ft.
Clear Span: 2.66 ft.
Total Span: 3.16 ft.
Live Load: 310 plf
Dead Load: 115 plf
Selfweight: 8.5 lbs
Dist. Selfweight: 2.91 plf
Total Weight: 9.2 lbs
Notes: Header Check
Beam Design 1210 Moncado
3/23/2022 1
d = 3.500 in.
3/23/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (34.92 + 3)] x (12 in./ft.)3 = 0.27 ft3
Volumespan = N[A x L] = 1 x [12.25 x 34.92] x (12 in./ft.)3 = 0.25 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.27 = 9.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.25 = 8.5 lbs
310 plf
115 plf
ws = 2.91 plf
2.91 ft.
2.66 ft.
3.16 ft.
676.10 lbs
676.10 lbs
3/23/2022 3
Fbx' = (900)(1.00)(1)(1)(1)(1.5)(1)(1) = 1350.0 psi
fb = = 760.6 psi
 fb = 760.6 psi < Fbx' = 1350.0 psi  (CSI = 0.56)   ➜  OK
3/23/2022 4
fv* = = 60.96 psi
 fv* = 60.96 psi < Fvx' = 180.00 psi  (CSI = 0.34)   ➜  OK
fv = = 76.24 psi
 fv = 76.24 psi < Fvx' = 180.00 psi  (CSI = 0.42)   ➜  OK
3/23/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 34.92 / 0.02 = 1397
 ΔLL = 0.02 in = L/1397 < L/360   ➜  OK
ΔTL = = 0.03 in.
(L/d)TL = 34.92 / 0.03 = 1012
 ΔTL = 0.03 in = L/1012 < L/240   ➜  OK
fc⊥ = = 64.4 psi
 fc⊥ = 64.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.10)   ➜  OK
3/23/2022 6
