Grade: 24F-V8 1.8E SP/SP
Size: 2.5 x 11
Design Span (L): 15.67 ft.
Clear Span: 15.33 ft.
Total Span: 16.00 ft.
Bearing (lb): 4 in.
Live Load: 200 lbs
Dead Load: 4000 lbs
Selfweight: 220.7 lbs
Dist. Selfweight: 14.09 plf
Total Weight: 225.4 lbs
Beam Design 2022A169
3/23/2022 1
b = 2.500 in.
d = 11.000 in.
A = 2.500 x 11.000 = 27.50 in.2
Sx = (2.500)(11.000)2/6 = 50.42 in.3
Sy = (2.500)2(11.000)/6 = 11.46 in.3
Ix = (2.500)(11.000)3/12 = 277.29 in.4
Iy = (2.500)3(11.000)/12 = 14.32 in.4
3/23/2022 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [27.50 x (188.00 + 4)] x (12 in./ft.)3 = 6.11 ft3
Volumespan = N[A x L] = 2 x [27.50 x 188.00] x (12 in./ft.)3 = 5.98 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 6.11 = 225.4 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 5.98 = 220.7 lbs
Distributed Self Weight (ws) = = 14.09 plf
200 lbs
4000 lbs
  ws = 14.09 plf
15.67 ft.
15.33 ft.
2212.72 lbs
2212.72 lbs
3/23/2022 3
fb = = 2009.2 psi
 fb = 2009.2 psi < Fbx' = 2400.0 psi  (CSI = 0.84)   ➜  OK
3/23/2022 4
fv* = = 59.93 psi
 fv* = 59.93 psi < Fvx' = 300.00 psi  (CSI = 0.20)   ➜  OK
fv = = 60.28 psi
 fv = 60.28 psi < Fvx' = 300.00 psi  (CSI = 0.20)   ➜  OK
3/23/2022 5
ΔLL =   =   = 0.03 in.
(L/d)LL = 188.00 / 0.03 = 6778
 ΔLL = 0.03 in = L/6778 < L/360   ➜  OK
ΔTL =   =   = 0.60 in.
(L/d)TL = 188.00 / 0.60 = 313
 ΔTL = 0.60 in = L/313 < L/240   ➜  OK
Ab = b x lb = 2.5 x 4 = 10.00 in2
fc⊥ = = 110.6 psi
 fc⊥ = 110.6 psi < Fc⊥x' = 740.00 psi  (CSI = 0.15)   ➜  OK
3/23/2022 6
