Design Span (L): 12.42 ft.
Clear Span: 12.17 ft.
Total Span: 12.67 ft.
Live Load: 70.8 plf
Dead Load: 30 plf
Selfweight: 40.9 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 41.8 lbs
Notes: up to 15 psf (30 lb/Ft uniform dead load) work shop lights-filtration light storage. good
Beam Design 2x10 24o/c 3.67/12 pitch
3/23/2022 1
3/23/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (149.04 + 3)] x (12 in./ft.)3 = 1.22 ft3
Volumespan = N[A x L] = 1 x [13.88 x 149.04] x (12 in./ft.)3 = 1.20 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.22 = 41.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.20 = 40.9 lbs
70.8 plf
30 plf
ws = 3.30 plf
12.42 ft.
12.17 ft.
12.67 ft.
659.45 lbs
659.45 lbs
3/23/2022 3
fb = = 1126.0 psi
 fb = 1126.0 psi < Fbx' = 1138.5 psi  (CSI = 0.99)   ➜  OK
3/23/2022 4
fv* = = 61.21 psi
 fv* = 61.21 psi < Fvx' = 207.00 psi  (CSI = 0.30)   ➜  OK
fv = = 69.88 psi
 fv = 69.88 psi < Fvx' = 207.00 psi  (CSI = 0.34)   ➜  OK
3/23/2022 5
ΔLL = = 0.24 in.
(L/d)LL = 149.04 / 0.24 = 622
 ΔLL = 0.24 in = L/622 < L/360   ➜  OK
ΔTL = = 0.35 in.
(L/d)TL = 149.04 / 0.35 = 423
 ΔTL = 0.35 in = L/423 < L/240   ➜  OK
fc⊥ = = 146.5 psi
 fc⊥ = 146.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.23)   ➜  OK
3/23/2022 6
