Design Span (L): 12.42 ft.
Clear Span: 12.17 ft.
Total Span: 12.67 ft.
Live Load: 70.8 plf
Dead Load: 2 plf
Selfweight: 40.9 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 41.8 lbs
Beam Design 2x10 24o/c 3.67/12 pitch
3/23/2022 1
3/23/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (149.04 + 3)] x (12 in./ft.)3 = 1.22 ft3
Volumespan = N[A x L] = 1 x [13.88 x 149.04] x (12 in./ft.)3 = 1.20 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.22 = 41.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.20 = 40.9 lbs
70.8 plf
2 plf
ws = 3.30 plf
12.42 ft.
12.17 ft.
12.67 ft.
482.07 lbs
482.07 lbs
3/23/2022 3
fb = = 823.1 psi
 fb = 823.1 psi < Fbx' = 1138.5 psi  (CSI = 0.72)   ➜  OK
3/23/2022 4
fv* = = 44.75 psi
 fv* = 44.75 psi < Fvx' = 207.00 psi  (CSI = 0.22)   ➜  OK
fv = = 51.09 psi
 fv = 51.09 psi < Fvx' = 207.00 psi  (CSI = 0.25)   ➜  OK
3/23/2022 5
ΔLL = = 0.24 in.
(L/d)LL = 149.04 / 0.24 = 622
 ΔLL = 0.24 in = L/622 < L/360   ➜  OK
ΔTL = = 0.26 in.
(L/d)TL = 149.04 / 0.26 = 579
 ΔTL = 0.26 in = L/579 < L/240   ➜  OK
fc⊥ = = 107.1 psi
 fc⊥ = 107.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
3/23/2022 6
