Design Span (L): 12.42 ft.
Clear Span: 12.17 ft.
Total Span: 12.67 ft.
Live Load: 70.8 plf
Dead Load: 2 plf
Selfweight: 49.8 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 50.8 lbs
Beam Design 2x12 24o/c 3.67/12 pitch
3/23/2022 1
3/23/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (149.04 + 3)] x (12 in./ft.)3 = 1.48 ft3
Volumespan = N[A x L] = 1 x [16.88 x 149.04] x (12 in./ft.)3 = 1.46 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.48 = 50.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.46 = 49.8 lbs
70.8 plf
2 plf
ws = 4.01 plf
12.42 ft.
12.17 ft.
12.67 ft.
486.58 lbs
486.58 lbs
3/23/2022 3
fb = = 561.7 psi
 fb = 561.7 psi < Fbx' = 1035.0 psi  (CSI = 0.54)   ➜  OK
3/23/2022 4
fv* = = 36.00 psi
 fv* = 36.00 psi < Fvx' = 207.00 psi  (CSI = 0.17)   ➜  OK
fv = = 42.40 psi
 fv = 42.40 psi < Fvx' = 207.00 psi  (CSI = 0.20)   ➜  OK
3/23/2022 5
ΔLL = = 0.13 in.
(L/d)LL = 149.04 / 0.13 = 1120
 ΔLL = 0.13 in = L/1120 < L/360   ➜  OK
ΔTL = = 0.14 in.
(L/d)TL = 149.04 / 0.14 = 1032
 ΔTL = 0.14 in = L/1032 < L/240   ➜  OK
fc⊥ = = 108.1 psi
 fc⊥ = 108.1 psi < Fc⊥x' = 625.00 psi  (CSI = 0.17)   ➜  OK
3/23/2022 6
