Size: 4 x 12
Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Live Load: 30 plf
Dead Load: 300 plf
Selfweight: 109.7 lbs
Dist. Selfweight: 10.21 plf
Total Weight: 112.3 lbs
CF Size Factor 1.1 1 - 1 - -
Beam Design 2022A16
1/9/2022 1
Beam Design 2022A16
1/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (129.00 + 3)] x (12 in./ft.)3 = 3.01 ft3
Volumespan = N[A x L] = 1 x [39.38 x 129.00] x (12 in./ft.)3 = 2.94 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.01 = 112.3 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.94 = 109.7 lbs
Distributed Self Weight (ws) = = 10.21 plf
30 plf
300 plf
ws = 10.21 plf
10.75 ft.
10.50 ft.
11.00 ft.
1871.14 lbs
1871.14 lbs
Beam Design 2022A16
1/9/2022 3
Fbx' = (750)(1.00)(1)(1)(1)(1.1)(1)(1) = 825.0 psi
fb = = 798.8 psi
 fb = 798.8 psi < Fbx' = 825.0 psi  (CSI = 0.97)   ➜  OK
Beam Design 2022A16
1/9/2022 4
fv* = = 57.51 psi
 fv* = 57.51 psi < Fvx' = 175.00 psi  (CSI = 0.33)   ➜  OK
fv = = 69.66 psi
 fv = 69.66 psi < Fvx' = 175.00 psi  (CSI = 0.40)   ➜  OK
Beam Design 2022A16
1/9/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 129.00 / 0.02 = 8320
 ΔLL = 0.02 in = L/8320 < L/360   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 129.00 / 0.18 = 734
 ΔTL = 0.18 in = L/734 < L/240   ➜  OK
fc⊥ = = 178.2 psi
 fc⊥ = 178.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.32)   ➜  OK
Beam Design 2022A16
1/9/2022 6
