Design Span (L): 13.58 ft.
Clear Span: 13.33 ft.
Total Span: 13.83 ft.
Live Load: 65 plf
Dead Load: 22 plf
Selfweight: 44.8 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 45.6 lbs
Notes: 28x28 cape 2x10 24o/c metal roofmain garage rafter load using Ps loading 65psf
Beam Design 28x28 2x10 24oc
3/22/2022 1
3/22/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (162.96 + 3)] x (12 in./ft.)3 = 1.33 ft3
Volumespan = N[A x L] = 1 x [13.88 x 162.96] x (12 in./ft.)3 = 1.31 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.33 = 45.6 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.31 = 44.8 lbs
65 plf
22 plf
ws = 3.30 plf
13.58 ft.
13.33 ft.
13.83 ft.
624.39 lbs
624.39 lbs
3/22/2022 3
fb = = 1167.7 psi
 fb = 1167.7 psi > Fbx' = 1138.5 psi  (CSI = 1.03)   ➜  NG
3/22/2022 4
fv* = = 58.76 psi
 fv* = 58.76 psi < Fvx' = 207.00 psi  (CSI = 0.28)   ➜  OK
fv = = 66.28 psi
 fv = 66.28 psi < Fvx' = 207.00 psi  (CSI = 0.32)   ➜  OK
3/22/2022 5
ΔLL = = 0.31 in.
(L/d)LL = 162.96 / 0.31 = 519
 ΔLL = 0.31 in = L/519 < L/360   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 162.96 / 0.44 = 373
 ΔTL = 0.44 in = L/373 < L/240   ➜  OK
fc⊥ = = 138.8 psi
 fc⊥ = 138.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.22)   ➜  OK
3/22/2022 6
