Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Live Load: 87.115 plf
Dead Load: 14.63 plf
Selfweight: 57.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 58.1 lbs
Notes: 28x28 2x12 16in o/c
Beam Design 2022A155
3/22/2022 1
3/22/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (171.00 + 3)] x (12 in./ft.)3 = 1.70 ft3
Volumespan = N[A x L] = 1 x [16.88 x 171.00] x (12 in./ft.)3 = 1.67 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.70 = 58.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.67 = 57.1 lbs
87.115 plf
14.63 plf
ws = 4.01 plf
14.25 ft.
14.50 ft.
766.71 lbs
766.71 lbs
3/22/2022 3
fb = = 1018.1 psi
 fb = 1018.1 psi < Fbx' = 1035.0 psi  (CSI = 0.98)   ➜  OK
3/22/2022 4
fv* = = 58.16 psi
 fv* = 58.16 psi < Fvx' = 207.00 psi  (CSI = 0.28)   ➜  OK
fv = = 66.98 psi
 fv = 66.98 psi < Fvx' = 207.00 psi  (CSI = 0.32)   ➜  OK
3/22/2022 5
ΔLL = = 0.28 in.
(L/d)LL = 171.00 / 0.28 = 602
 ΔLL = 0.28 in = L/602 < L/360   ➜  OK
ΔTL = = 0.34 in.
(L/d)TL = 171.00 / 0.34 = 496
 ΔTL = 0.34 in = L/496 < L/240   ➜  OK
fc⊥ = = 170.4 psi
 fc⊥ = 170.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.27)   ➜  OK
3/22/2022 6
