Grade: DF SS
Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Live Load: 87.115 plf
Dead Load: 14.63 plf
Selfweight: 114.2 lbs
Dist. Selfweight: 8.02 plf
Total Weight: 116.2 lbs
Notes: 28x28 2x12 16in o/c
Beam Design 2022A154
3/22/2022 1
3/22/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (171.00 + 3)] x (12 in./ft.)3 = 3.40 ft3
Volumespan = N[A x L] = 2 x [16.88 x 171.00] x (12 in./ft.)3 = 3.34 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.40 = 116.2 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.34 = 114.2 lbs
87.115 plf
14.63 plf
ws = 8.02 plf
14.25 ft.
14.50 ft.
795.77 lbs
795.77 lbs
3/22/2022 3
Fbx' = (1500)(1.15)(1)(1)(1)(1)(1)(1) = 1725.0 psi
fb = = 528.3 psi
 fb = 528.3 psi < Fbx' = 1725.0 psi  (CSI = 0.31)   ➜  OK
3/22/2022 4
fv* = = 30.18 psi
 fv* = 30.18 psi < Fvx' = 207.00 psi  (CSI = 0.15)   ➜  OK
fv = = 34.76 psi
 fv = 34.76 psi < Fvx' = 207.00 psi  (CSI = 0.17)   ➜  OK
3/22/2022 5
ΔLL = = 0.12 in.
(L/d)LL = 171.00 / 0.12 = 1431
 ΔLL = 0.12 in = L/1431 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 171.00 / 0.15 = 1136
 ΔTL = 0.15 in = L/1136 < L/240   ➜  OK
fc⊥ = = 88.4 psi
 fc⊥ = 88.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.14)   ➜  OK
3/22/2022 6
