Design Span (L): 14.25 ft.
Clear Span: 14.00 ft.
Total Span: 14.50 ft.
Live Load: 131 plf
Dead Load: 40 plf
Selfweight: 47.0 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 47.8 lbs
Orientation: Horizontal
Notes: 28x28 2x10 rafter
Beam Design 2022A152
3/22/2022 1
3/22/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (171.00 + 3)] x (12 in./ft.)3 = 1.40 ft3
Volumespan = N[A x L] = 1 x [13.88 x 171.00] x (12 in./ft.)3 = 1.37 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.40 = 47.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.37 = 47.0 lbs
131 plf
40 plf
ws = 3.30 plf
14.25 ft.
14.50 ft.
1263.64 lbs
1263.64 lbs
3/22/2022 3
Fby' = (900)(1.15)(1)(1)(1)(1.1)(1.2)(1)(1) = 1366.2 psi
fb = = 15305.0 psi
 fb = 15305.0 psi > Fby' = 1366.2 psi  (CSI = 11.20)   ➜  NG
3/22/2022 4
fv* = = 131.90 psi
 fv* = 131.90 psi < Fvy' = 207.00 psi  (CSI = 0.64)   ➜  OK
fv = = 134.25 psi
 fv = 134.25 psi < Fvy' = 207.00 psi  (CSI = 0.65)   ➜  OK
3/22/2022 5
ΔLL = = 29.20 in.
(L/d)LL = 171.00 / 29.20 = 6
 ΔLL = 29.20 in = L/6 > L/360   ➜  NG
ΔTL = = 38.85 in.
(L/d)TL = 171.00 / 38.85 = 4
 ΔTL = 38.85 in = L/4 > L/240   ➜  NG
Ab = d x lb = 9.25 x 3 = 27.75 in2
fc⊥ = = 45.5 psi
 fc⊥ = 45.5 psi < Fc⊥y' = 625.00 psi  (CSI = 0.07)   ➜  OK
3/22/2022 6
