Design Span (L): 12.25 ft.
Clear Span: 12.00 ft.
Total Span: 12.50 ft.
Live Load: 5800 lbs
Dead Load: 2520 lbs
Selfweight: 147.3 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 150.3 lbs
Beam Design 2022A148
3/17/2022 1
3/17/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (147.00 + 3)] x (12 in./ft.)3 = 4.39 ft3
Volumespan = N[A x L] = 3 x [16.88 x 147.00] x (12 in./ft.)3 = 4.31 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.39 = 150.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.31 = 147.3 lbs
5800 lbs
2520 lbs
ws = 12.02 plf
12.25 ft.
12.50 ft.
4235.15 lbs
4235.15 lbs
3/17/2022 3
fb = = 3249.7 psi
 fb = 3249.7 psi > Fbx' = 1035.0 psi  (CSI = 3.14)   ➜  NG
3/17/2022 4
fv* = = 125.11 psi
 fv* = 125.11 psi < Fvx' = 207.00 psi  (CSI = 0.60)   ➜  OK
fv = = 125.44 psi
 fv = 125.44 psi < Fvx' = 207.00 psi  (CSI = 0.61)   ➜  OK
3/17/2022 5
ΔLL =   =   = 0.45 in.
(L/d)LL = 147.00 / 0.45 = 327
 ΔLL = 0.45 in = L/327 > L/360   ➜  NG
ΔTL =   =   = 0.65 in.
(L/d)TL = 147.00 / 0.65 = 226
 ΔTL = 0.65 in = L/226 > L/240   ➜  NG
fc⊥ = = 313.7 psi
 fc⊥ = 313.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.50)   ➜  OK
3/17/2022 6
