Grade: SP No.1
Design Span (L): 9.71 ft.
Clear Span: 9.25 ft.
Total Span: 10.17 ft.
Bearing (lb): 5.5 in.
Live Load: 262.5 plf
Dead Load: 127.5 plf
Selfweight: 56.6 lbs
Dist. Selfweight: 5.83 plf
Total Weight: 59.2 lbs
Beam Design 2022A144
3/16/2022 1
SP No.1 1250 800 175 565 1500 1600000 580000 0.55
3/16/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (116.50 + 5.5)] x (12 in./ft.)3 = 1.54 ft3
Volumespan = N[A x L] = 2 x [10.88 x 116.50] x (12 in./ft.)3 = 1.47 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 1.54 = 59.2 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 1.47 = 56.6 lbs
Distributed Self Weight (ws) = = 5.83 plf
262.5 plf
127.5 plf
ws = 5.83 plf
9.71 ft.
9.25 ft.
10.17 ft.
2012.06 lbs
2012.06 lbs
3/16/2022 3
Fbx' = (1250)(1.15)(0.85)(1)(1)(1)(1)(1) = 1221.9 psi
fb = = 2129.2 psi
 fb = 2129.2 psi > Fbx' = 1221.9 psi  (CSI = 1.74)   ➜  NG
3/16/2022 4
fv* = = 116.01 psi
 fv* = 116.01 psi < Fvx' = 195.21 psi  (CSI = 0.59)   ➜  OK
fv = = 132.51 psi
 fv = 132.51 psi < Fvx' = 195.21 psi  (CSI = 0.68)   ➜  OK
3/16/2022 5
ΔLL = = 0.38 in.
(L/d)LL = 116.50 / 0.38 = 305
 ΔLL = 0.38 in = L/305 < L/180   ➜  OK
ΔTL = = 0.58 in.
(L/d)TL = 116.50 / 0.58 = 202
 ΔTL = 0.58 in = L/202 < L/120   ➜  OK
fc⊥ = = 121.9 psi
 fc⊥ = 121.9 psi < Fc⊥x' = 378.55 psi  (CSI = 0.32)   ➜  OK
3/16/2022 6
