Size: 4 x 12
Design Span (L): 6.72 ft.
Clear Span: 6.13 ft.
Total Span: 7.30 ft.
Bearing (lb): 7 in.
Live Load: 374 plf
Dead Load: 3.5 plf
Selfweight: 137.1 lbs
Dist. Selfweight: 20.41 plf
Total Weight: 149.0 lbs
Incised Lumber: Yes
CF Size Factor 1.1 1 - 1 - -
Beam Design 2022A142
3/16/2022 1
3/16/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [39.38 x (80.60 + 7)] x (12 in./ft.)3 = 3.99 ft3
Volumespan = N[A x L] = 2 x [39.38 x 80.60] x (12 in./ft.)3 = 3.67 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.99 = 149.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.67 = 137.1 lbs
Distributed Self Weight (ws) = = 20.41 plf
374 plf
3.5 plf
ws = 20.41 plf
6.72 ft.
6.13 ft.
7.30 ft.
1452.46 lbs
1452.46 lbs
3/16/2022 3
Fbx' = (750)(1.15)(1)(1)(1)(1.1)(0.8)(1) = 759.0 psi
fb = = 182.4 psi
 fb = 182.4 psi < Fbx' = 759.0 psi  (CSI = 0.24)   ➜  OK
3/16/2022 4
Fvx' = (175)(1.15)(1)(1)(0.8) = 161.00 psi
fv* = = 18.35 psi
 fv* = 18.35 psi < Fvx' = 161.00 psi  (CSI = 0.11)   ➜  OK
fv = = 25.46 psi
 fv = 25.46 psi < Fvx' = 161.00 psi  (CSI = 0.16)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1400000(1)(1)(0.95) = 1330000 psi
3/16/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 80.60 / 0.02 = 5198
 ΔLL = 0.02 in = L/5198 < L/360   ➜  OK
ΔTL = = 0.02 in.
(L/d)TL = 80.60 / 0.02 = 4885
 ΔTL = 0.02 in = L/4885 < L/240   ➜  OK
Ab = b x lb = 3.5 x 7 = 24.50 in2
fc⊥ = = 29.6 psi
 fc⊥ = 29.6 psi < Fc⊥x' = 565.00 psi  (CSI = 0.05)   ➜  OK
3/16/2022 6
