Design Span (L): 9.63 ft.
Clear Span: 9.50 ft.
Total Span: 9.75 ft.
Bearing (lb): 1.5 in.
Live Load: 150 plf
Dead Load: 0 plf
Selfweight: 81.4 lbs
Dist. Selfweight: 8.46 plf
Total Weight: 82.5 lbs
Load Duration: 1.60
CL Beam Stability Factor 0.989 - - - - -
Beam Design 2022A140
3/16/2022 1
3/16/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (115.50 + 1.5)] x (12 in./ft.)3 = 2.21 ft3
Volumespan = N[A x L] = 3 x [10.88 x 115.50] x (12 in./ft.)3 = 2.18 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 2.21 = 82.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 2.18 = 81.4 lbs
Distributed Self Weight (ws) = = 8.46 plf
150 plf
0 plf
ws = 8.46 plf
9.63 ft.
9.50 ft.
9.75 ft.
772.48 lbs
772.48 lbs
3/16/2022 3
lu = Unbraced Length = 9.625 ft.
lu/d = = 15.93
le = 1.63lu + 3d = 1.63(115.5) + 3(7.25) = 210.01 in. = 17.50 ft.  (NDS Table 3.3.3)
Rb = = 8.67
 Rb = 8.67 < 50   ➜  OK
3/16/2022 4
FbE = = 8139.32 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (925)(1.60)(1)(1)(1)(1)(1) = 1480.00 psi
CL =   = 0.989
Fbx' = (925)(1.60)(1)(1)(0.989)(1)(1)(1) = 1463.9 psi
fb = = 558.6 psi
 fb = 558.6 psi < Fbx' = 1463.9 psi  (CSI = 0.38)   ➜  OK
Fvx' = (175)(1.60)(1)(1)(1) = 280.00 psi
fv* = = 30.66 psi
 fv* = 30.66 psi < Fvx' = 280.00 psi  (CSI = 0.11)   ➜  OK
fv = = 35.06 psi
 fv = 35.06 psi < Fvx' = 280.00 psi  (CSI = 0.13)   ➜  OK
3/16/2022 5
ΔLL = = 0.14 in.
(L/d)LL = 115.50 / 0.14 = 798
 ΔLL = 0.14 in = L/798 < L/360   ➜  OK
ΔTL = = 0.15 in.
(L/d)TL = 115.50 / 0.15 = 755
 ΔTL = 0.15 in = L/755 < L/240   ➜  OK
fc⊥ = = 114.4 psi
 fc⊥ = 114.4 psi < Fc⊥x' = 565.00 psi  (CSI = 0.20)   ➜  OK
3/16/2022 6
