Species: Hem-Fir
Grade: HF No.2
Size: 4 x 8
Design Span (L): 5.33 ft.
Clear Span: 5.08 ft.
Total Span: 5.58 ft.
Live Load: 460 plf
Dead Load: 212 plf
Selfweight: 27.9 lbs
Dist. Selfweight: 5.24 plf
Total Weight: 29.2 lbs
Incised Lumber: Yes
Beam Design 2022A14
1/8/2022 1
G = 0.43
Beam Design 2022A14
1/8/2022 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [25.38 x (63.96 + 3)] x (12 in./ft.)3 = 0.98 ft3
Volumespan = N[A x L] = 1 x [25.38 x 63.96] x (12 in./ft.)3 = 0.94 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 0.98 = 29.2 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 0.94 = 27.9 lbs
Distributed Self Weight (ws) = = 5.24 plf
460 plf
212 plf
ws = 5.24 plf
5.33 ft.
5.08 ft.
5.58 ft.
1889.50 lbs
1889.50 lbs
Beam Design 2022A14
1/8/2022 3
Fbx' = (850)(1.15)(1)(1)(1)(1.3)(0.8)(1) = 1016.6 psi
fb = = 941.2 psi
 fb = 941.2 psi < Fbx' = 1016.6 psi  (CSI = 0.93)   ➜  OK
Beam Design 2022A14
1/8/2022 4
Fvx' = (150)(1.15)(1)(1)(0.8) = 138.00 psi
fv* = = 82.50 psi
 fv* = 82.50 psi < Fvx' = 138.00 psi  (CSI = 0.60)   ➜  OK
fv = = 106.69 psi
 fv = 106.69 psi < Fvx' = 138.00 psi  (CSI = 0.77)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(1)(1)(0.95) = 1235000 psi
Beam Design 2022A14
1/8/2022 5
ΔLL = = 0.06 in.
(L/d)LL = 63.96 / 0.06 = 1051
 ΔLL = 0.06 in = L/1051 < L/360   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 63.96 / 0.09 = 714
 ΔTL = 0.09 in = L/714 < L/240   ➜  OK
fc⊥ = = 180.0 psi
 fc⊥ = 180.0 psi < Fc⊥x' = 405.00 psi  (CSI = 0.44)   ➜  OK
Beam Design 2022A14
1/8/2022 6
