Species: Hem-Fir
Grade: HF No.2
Design Span (L): 1.63 ft.
Clear Span: 1.38 ft.
Total Span: 1.88 ft.
Live Load: 250 lbs
Dead Load: 3000 lbs
Selfweight: 5.5 lbs
Dist. Selfweight: 3.41 plf
Total Weight: 6.4 lbs
Defl. Limits: 480|360
Beam Design 2022A135
3/14/2022 1
G = 0.43
3/14/2022 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (19.50 + 3)] x (12 in./ft.)3 = 0.21 ft3
Volumespan = N[A x L] = 2 x [8.25 x 19.50] x (12 in./ft.)3 = 0.19 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 0.21 = 6.4 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 0.19 = 5.5 lbs
Distributed Self Weight (ws) = = 3.41 plf
250 lbs
3000 lbs
ws = 3.41 plf
1.63 ft.
1.38 ft.
1.88 ft.
1628.20 lbs
1628.20 lbs
3/14/2022 3
lu = Unbraced Length = 1.625 ft.
lu/d = = 3.55
le = 1.8lu = 1.8(19.5) = 35.10 in. = 2.93 ft.  (NDS Table 3.3.3)
Rb = = 4.63
 Rb = 4.63 < 50   ➜  OK
3/14/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 470000(1)(1)(1) = 470000 psi
FbE = = 26293.71 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (850)(1.00)(1)(1)(1.3)(1)(1.15) = 1270.75 psi
CL =   = 0.997
Fbx' = (850)(1.00)(1)(1)(0.997)(1.3)(1)(1.15) = 1267.5 psi
fb = = 1048.4 psi
 fb = 1048.4 psi < Fbx' = 1267.5 psi  (CSI = 0.83)   ➜  OK
Fvx' = (150)(1.00)(1)(1)(1) = 150.00 psi
fv* = = 147.84 psi
 fv* = 147.84 psi < Fvx' = 150.00 psi  (CSI = 0.99)   ➜  OK
fv = = 147.98 psi
 fv = 147.98 psi < Fvx' = 150.00 psi  (CSI = 0.99)   ➜  OK
3/14/2022 5
LL Allowable: L/480
TL Allowable: L/360
ΔLL =   =   = 0.00 in.
(L/d)LL = 19.50 / 0.00 = 27303
 ΔLL = 0.00 in = L/27303 < L/480   ➜  OK
ΔTL =   =   = 0.01 in.
(L/d)TL = 19.50 / 0.01 = 2098
 ΔTL = 0.01 in = L/2098 < L/360   ➜  OK
fc⊥ = = 180.9 psi
 fc⊥ = 180.9 psi < Fc⊥x' = 405.00 psi  (CSI = 0.45)   ➜  OK
3/14/2022 6
