Grade: DF No.1 & Btr
Size: 4 x 4
Design Span (L): 1.63 ft.
Clear Span: 1.38 ft.
Total Span: 1.88 ft.
Live Load: 250 lbs
Dead Load: 3000 lbs
Selfweight: 9.5 lbs
Dist. Selfweight: 5.82 plf
Total Weight: 10.9 lbs
Beam Design 2022A132
3/14/2022 1
d = 3.500 in.
3/14/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [12.25 x (19.50 + 3)] x (12 in./ft.)3 = 0.32 ft3
Volumespan = N[A x L] = 2 x [12.25 x 19.50] x (12 in./ft.)3 = 0.28 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.32 = 10.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.28 = 9.5 lbs
Distributed Self Weight (ws) = = 5.82 plf
250 lbs
3000 lbs
ws = 5.82 plf
1.63 ft.
1.38 ft.
1.88 ft.
1630.46 lbs
1630.46 lbs
3/14/2022 3
Fbx' = (1200)(1.00)(1)(1)(1)(1.5)(1)(1) = 1800.0 psi
fb = = 1110.2 psi
 fb = 1110.2 psi < Fbx' = 1800.0 psi  (CSI = 0.62)   ➜  OK
3/14/2022 4
fv* = = 99.68 psi
 fv* = 99.68 psi < Fvx' = 180.00 psi  (CSI = 0.55)   ➜  OK
fv = = 99.78 psi
 fv = 99.78 psi < Fvx' = 180.00 psi  (CSI = 0.55)   ➜  OK
3/14/2022 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 19.50 / 0.00 = 22731
 ΔLL = 0.00 in = L/22731 < L/360   ➜  OK
ΔTL =   =   = 0.01 in.
(L/d)TL = 19.50 / 0.01 = 1745
 ΔTL = 0.01 in = L/1745 < L/240   ➜  OK
fc⊥ = = 77.6 psi
 fc⊥ = 77.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.12)   ➜  OK
3/14/2022 6
