Grade: SPF No.2
Design Span (L): 1.63 ft.
Clear Span: 1.38 ft.
Total Span: 1.88 ft.
Live Load: 250 lbs
Dead Load: 2500 lbs
Selfweight: 5.4 lbs
Dist. Selfweight: 3.33 plf
Total Weight: 6.3 lbs
Beam Design 2022A131
3/14/2022 1
3/14/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (19.50 + 3)] x (12 in./ft.)3 = 0.21 ft3
Volumespan = N[A x L] = 2 x [8.25 x 19.50] x (12 in./ft.)3 = 0.19 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 0.21 = 6.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 0.19 = 5.4 lbs
Distributed Self Weight (ws) = = 3.33 plf
250 lbs
2500 lbs
ws = 3.33 plf
1.63 ft.
1.38 ft.
1.88 ft.
1378.13 lbs
1378.13 lbs
3/14/2022 3
lu = Unbraced Length = 1.625 ft.
lu/d = = 3.55
le = 1.8lu = 1.8(19.5) = 35.10 in. = 2.93 ft.  (NDS Table 3.3.3)
Rb = = 4.63
 Rb = 4.63 < 50   ➜  OK
3/14/2022 4
FbE = = 28531.47 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (875)(1.00)(1)(1)(1.3)(1)(1) = 1137.50 psi
CL =   = 0.998
Fbx' = (875)(1.00)(1)(1)(0.998)(1.3)(1)(1) = 1135.1 psi
fb = = 887.2 psi
 fb = 887.2 psi < Fbx' = 1135.1 psi  (CSI = 0.78)   ➜  OK
fv* = = 125.11 psi
 fv* = 125.11 psi < Fvx' = 135.00 psi  (CSI = 0.93)   ➜  OK
fv = = 125.25 psi
 fv = 125.25 psi < Fvx' = 135.00 psi  (CSI = 0.93)   ➜  OK
3/14/2022 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 19.50 / 0.00 = 29403
 ΔLL = 0.00 in = L/29403 < L/360   ➜  OK
ΔTL =   =   = 0.01 in.
(L/d)TL = 19.50 / 0.01 = 2670
 ΔTL = 0.01 in = L/2670 < L/240   ➜  OK
fc⊥ = = 153.1 psi
 fc⊥ = 153.1 psi < Fc⊥x' = 425.00 psi  (CSI = 0.36)   ➜  OK
3/14/2022 6
