Species: Hem-Fir
Grade: HF No.2
Design Span (L): 4.25 ft.
Clear Span: 4.00 ft.
Total Span: 4.50 ft.
Live Load: 250 lbs
Dead Load: 4000 lbs
Selfweight: 7.2 lbs
Dist. Selfweight: 1.70 plf
Total Weight: 7.7 lbs
CL Beam Stability Factor 0.968 - - - - -
Beam Design 2022A130
3/14/2022 1
G = 0.43
3/14/2022 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (51.00 + 3)] x (12 in./ft.)3 = 0.26 ft3
Volumespan = N[A x L] = 1 x [8.25 x 51.00] x (12 in./ft.)3 = 0.24 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 0.26 = 7.7 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 0.24 = 7.2 lbs
Distributed Self Weight (ws) = = 1.70 plf
250 lbs
4000 lbs
ws = 1.70 plf
4.25 ft.
4.00 ft.
4.50 ft.
2128.83 lbs
2128.83 lbs
3/14/2022 3
lu = Unbraced Length = 4.250 ft.
lu/d = = 9.27
le = 1.37lu + 3d = 1.37(51.0) + 3(5.5) = 86.37 in. = 7.20 ft.  (NDS Table 3.3.3)
Rb = = 14.53
 Rb = 14.53 < 50   ➜  OK
3/14/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 470000(1)(1)(1) = 470000 psi
FbE = = 2671.38 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (850)(1.00)(1)(1)(1.3)(1)(1) = 1105.00 psi
CL =   = 0.968
Fbx' = (850)(1.00)(1)(1)(0.968)(1.3)(1)(1) = 1069.3 psi
fb = = 7171.4 psi
 fb = 7171.4 psi > Fbx' = 1069.3 psi  (CSI = 6.71)   ➜  NG
Fvx' = (150)(1.00)(1)(1)(1) = 150.00 psi
fv* = = 386.88 psi
 fv* = 386.88 psi > Fvx' = 150.00 psi  (CSI = 2.58)   ➜  NG
fv = = 387.02 psi
 fv = 387.02 psi > Fvx' = 150.00 psi  (CSI = 2.58)   ➜  NG
3/14/2022 5
ΔLL =   =   = 0.03 in.
(L/d)LL = 51.00 / 0.03 = 1996
 ΔLL = 0.03 in = L/1996 < L/360   ➜  OK
ΔTL =   =   = 0.43 in.
(L/d)TL = 51.00 / 0.43 = 117
 ΔTL = 0.43 in = L/117 > L/240   ➜  NG
fc⊥ = = 473.1 psi
 fc⊥ = 473.1 psi > Fc⊥x' = 405.00 psi  (CSI = 1.17)   ➜  NG
3/14/2022 6
