Beam Design - 1920
Grade: DF SS
Design Span (L): 15.00 ft.
Clear Span: 14.00 ft.
Total Span: 16.00 ft.
Bearing (lb): 12 in.
Selfweight: 98.9 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 105.5 lbs
Notes: Double 2x12 at 8ft on Center. 2x6 Joists at 12 inches on center. Upper Floor Support.
Beam Design Dennis Langat Kericho Kenya 1920
3/12/2022 1
3/12/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [13.88 x (180.00 + 12)] x (12 in./ft.)3 = 3.08 ft3
Volumespan = N[A x L] = 2 x [13.88 x 180.00] x (12 in./ft.)3 = 2.89 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.08 = 105.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.89 = 98.9 lbs
ws = 6.59 plf
15.00 ft.
1452.73 lbs
1452.73 lbs
3/12/2022 3
Fbx' = (1500)(1.15)(1)(1)(1)(1.1)(1)(1) = 1897.5 psi
fb = = 1432.6 psi
 fb = 1432.6 psi < Fbx' = 1897.5 psi  (CSI = 0.75)   ➜  OK
3/12/2022 4
fv* = = 66.05 psi
 fv* = 66.05 psi < Fvx' = 207.00 psi  (CSI = 0.32)   ➜  OK
fv = = 73.62 psi
 fv = 73.62 psi < Fvx' = 207.00 psi  (CSI = 0.36)   ➜  OK
3/12/2022 5
ΔLL = = 0.30 in.
(L/d)LL = 180.00 / 0.30 = 594
 ΔLL = 0.30 in = L/594 < L/360   ➜  OK
ΔTL = = 0.55 in.
(L/d)TL = 180.00 / 0.55 = 327
 ΔTL = 0.55 in = L/327 < L/240   ➜  OK
Ab = b x lb = 1.5 x 12 = 18.00 in2
fc⊥ = = 40.4 psi
 fc⊥ = 40.4 psi < Fc⊥x' = 625.00 psi  (CSI = 0.06)   ➜  OK
3/12/2022 6
